hydraulic or manual tensioner on h22a1???
Old Apr 18, 2005 | 06:07 PM
just22d's Avatar
Default hydraulic or manual tensioner on h22a1???
I have recently attempted to install a manual tensioner on my h22a1 motor. Honda Tuning says that any h23 manual tensioner should bolt right up but I can't seem to find where the "slide lock" bolt goes. Another problem is what should I do with my balancer shaft belt, I have heard of people taking them off and not using them at all, how do I make this possible..............
Old Apr 19, 2005 | 07:29 AM
IHateJDM's Avatar
Default Re: hydraulic or manual tensioner on h22a1??? (just22d)
put down honda tuning and search the archives, you'll get better info for your "slide lock" problem (I don't know the names of all the tiny parts for that conversion). I know there is a write up with pics if you search. As far as the balance shafts, you can put the belt on them and use them, you can leave the belt off and just let them sit there, or you can take them out and plug the oil feed lines. The third option is the hardest, and I would recommend one of the first two.
Old Apr 20, 2005 | 04:08 PM
just22d's Avatar
Default Re: hydraulic or manual tensioner on h22a1??? (IHateJDM)
Thanks....
Old Apr 20, 2005 | 11:25 PM
SixguN's Avatar
I think this is what IHateJDM is talking about:
https://honda-tech.com/zerothread?id=549516
Crxh22ajdm
Dec 9, 2012 06:07 AM
cparreno
Aug 22, 2010 07:52 AM
black94lude
Jan 5, 2010 04:04 PM
94jdmlude
Dec 22, 2008 01:24 PM
Ziggymidget5
May 22, 2005 03:38 PM
