d16z6 in 91 civic, guages not working coolant temp switch?
Old Apr 18, 2005 | 05:58 PM
othick's Avatar
Default d16z6 in 91 civic, guages not working coolant temp switch?
I just finished putting a d16z6 in my 91 civic si. There is a plug on the back of the block with 2 prongs wich I assume is the coolant temp switch? I can't screw it into the z6 block, is there a place to hook it up on the z6 engine? Also none of my guages work now, tach, fuel, everything. Has anyone had a problem with this? I used a p28 ecu and dizzy with a jumper harness from rywire. Car runs good but just has these two problems.
JRZ88DX
May 20, 2010 01:23 PM
efking1985
Feb 2, 2007 11:14 AM
posterfee
Jan 12, 2006 07:54 PM
iNetForce
May 24, 2004 08:05 PM
KevronsEG
Apr 25, 2003 01:31 PM
