Blown valve cover gasket! WTF?? Why did it happen?
Old Jan 30, 2002 | 02:26 PM
Cryptopsy's Avatar
Default Blown valve cover gasket! WTF?? Why did it happen?
Ok. There I was, happy to be going home from work, got the KoRn pumped up loud, then all of a sudden *sniff sniff*... SMOKE in the cabin!
So I get home, pop the hood and the valve cover gasket has blown out on the front (right above my hedders). Texas tea was everywhere! So I rip the cover off and look at the gasket...looks good. No cracks or tears, it just was blown from the little groove that it sits in.
My question is...what the f*ck happened? My cover was bolted down tight (I think) but is there any other explanation to this? By the way, when I started my car, it was -4 degrees F. (Cold canadian prairie weather) Isnt there a sensor that releases head pressure?
Thanks guys. Please reply ASAP!
Old Jan 30, 2002 | 05:10 PM
Cryptopsy's Avatar
Default Re: Blown valve cover gasket! WTF?? Why did it happen? (SoulflyCRXsi)
Wow! I can't believe nobody here knew the answer. Well I figured it out. I had some condensation in that hose that comes off the valve cover (that goes to intake) and that froze up and caused backpressure.
Old Jan 30, 2002 | 05:12 PM
wuhungsixxx's Avatar
New User
u know what i was thinking that it could be clogged...but i didnt wanna say any thing cuz i didnt wanna look stupid...hehe
Old Jan 30, 2002 | 05:18 PM
brad.'s Avatar
siiick, never heard of a clogged breather tube
Old Jan 31, 2002 | 09:56 AM
SiR Kid's Avatar
New User
Default Re: Blown valve cover gasket! WTF?? Why did it happen? ([626]JDM-b16a-EF9)
I blew mine off from boost on a pair of burned pistons
Lookie.... See it just to the left of the wastegate? That blew oil EVERYWHERE in my engine bay
[Modified by SiR Kid, 1:18 PM 1/31/2002]
Old Jan 31, 2002 | 06:12 PM
Cryptopsy's Avatar
Default Re: Blown valve cover gasket! WTF?? Why did it happen? (SiR Kid)
[QUOTE]I blew mine off from boost on a pair of burned pistons
Lookie.... See it just to the left of the wastegate? That blew oil EVERYWHERE in my engine bay [QUOTE]
Hey man, mine looked like that too...and I dont have all the goodies under the hood like you do! Can you please explain to me your setup? I am very interested, and it looks pretty tight...
Old Feb 1, 2002 | 07:27 PM
SiR Kid's Avatar
New User
I posted a while back all my mods, but I can't find the post... welp, back to the search engine
[edit] found it all
Here's the setup: It should make 350-400 at the wheels at 18+ PSI.
B16a Controlled by a Z-Dyne Gold Programmable ECU
ITR Cams
ITR Intake Manifold
ITR Valve Springs
JG 64mm Throttle Body
Eagle Rods
Endyne Pistons - .010 over, 9:1 compression - Polished, then ceramic coated skirts and tops
550CC Venom Injectors
Eclipse GS-T Uprade Pump
F-Max Manifold
Deltagate Wastegate
Garrett 4/3 hybrid Turbo .50 a/r compressor
Custom Downpipe to keep a/c
Custom Piping
Spearco Liquid/Air intercooler
1.5 Gallon Reservoir in the stock resonator location behind bumper
4 pass hi flow heat exchanger by Cool-Tek for the intercooler system
70 GPH bilge pump
GReddy BOV and Turbo Timer
GReddy Profec B
GReddy EGT, Oil Pressure, and Boost Gauges
Suspension is a WIP, but so far I've got:
Tokiko 5 way adjustables at all corners
Ground Control Coilover Sleeves <will have 400/350 rate springs soon>
16" ADR DTM Wheels with Nitto 555 205/45/16 Tires
Brakes Will Be 12" Wilwood in the front. <hopefully, maybe just Fastbrakes 10.2" kit.>
I have 93 Integra GS brakes in the rear now.
Sound good?
[/edit]
[Modified by SiR Kid, 10:35 PM 2/1/2002]
Mr Ohms
Dec 10, 2012 06:15 PM
dc5tegk20
Aug 24, 2006 12:40 AM
fanta!
Jun 29, 2005 03:20 PM
xd69
Oct 16, 2004 11:22 PM
94ls
Mar 26, 2003 10:47 AM
