URGENT :How to LOWER boost with Tial style wastegate
Old Apr 18, 2005 | 05:15 PM
ATgrills.com's Avatar
Default URGENT :How to LOWER boost with Tial style wastegate
A friend is getting his car tunned tomo morning at 9 so we need to lower the boost with another alternative then getting a new spring...
He has a imitation Tial 38MM wastegate (he has the SS autochrome one)
that came with a blue spring,, which is like 20PSI...
I need to know if we can cut the spring... to lower the boost..
He has a manual boost controler so if he sets it too lowe he can put it back up!
thanks
Tyler
Old Apr 18, 2005 | 05:23 PM
Ben Huynh's Avatar
Default Re: URGENT :How to LOWER boost with Tial style wastegate (ATgrills.com)
There's nothing you can do other than swapping out the spring. Cutting the spring should never be attempted.
Old Apr 18, 2005 | 05:27 PM
B18 rider's Avatar
What if its done Temporally
Old Apr 18, 2005 | 05:48 PM
Emshhh's Avatar
Default Re: URGENT :How to LOWER boost with Tial style wastegate (ben@importparts.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ben@importparts.com &raquo;</TD></TR><TR><TD CLASS="quote">There's nothing you can do other than swapping out the spring. Cutting the spring should never be attempted.</TD></TR></TABLE>
Old Apr 18, 2005 | 05:51 PM
batboyvaj's Avatar
Default Re: URGENT :How to LOWER boost with Tial style wastegate (iGfrequency)
don't cut the spring....just don't cheap out. a new spring is cheaper than a new motor.
Old Apr 18, 2005 | 05:58 PM
Default Re: URGENT :How to LOWER boost with Tial style wastegate (batboyvaj)
Listen Its not about the money,, the car is getting tunned tomo at 9 in the morning
I dont care if the spring is 100$
I just need to know if I can cut the spring,,,,
Old Apr 18, 2005 | 06:13 PM
wantboost's Avatar
Who is Mr Robot?
you cant cut the spring..... if the spring were shorter then the vavle would stay open because the spring wouldnt be long enough to keep the valve seated..
dont half-*** it... buy a new spring, you might have to postpone the tuning date.... but waiting is better than building a new motor
Old Apr 18, 2005 | 06:19 PM
Default Re: URGENT :How to LOWER boost with Tial style wastegate (wantboost)
dont really wanna cancel on the tunner the same say since I think he will be reallllly pissed,,, since he has a big waiting list
so as long as I dont cut the spring like crazy I should be ok right???
To make it clear, the spring will still need to be long enough to have pressure against the cap of the wastegate..basically I will need tp push it down when I am putting the screws back in!
that make any sense?
Old Apr 18, 2005 | 06:21 PM
wantboost's Avatar
Who is Mr Robot?
no, dont cut the spring at all..
if the valve is open by the tiniest bit... exhaust gases will bypass the turbo, slowing response and really throwing the tune off once you get the proper spring... plus you cant cut a 20psi pring enough to get it down to 8 psi or so
if the spring is cut by even 1mm, thats 1mm that the valve is open.
DO NOT CUT THE SPRING WHAT SO EVER
Old Apr 18, 2005 | 06:31 PM
i dont think its open at all.. literally i needed 2 people to push down on the cap of the wastegate to close the top and put the screws in,,, the spring is big and hard...
so i think i can cut off like 3 rings before there would be no pressure gainst the top of the wastegate!
Old Apr 18, 2005 | 06:35 PM
oxSLEEPERxo's Avatar
i would try buy a spring or borrow a spring from someone around you or buy one from that tuner, most likely he will have one laying around or so that you can buy or use
Old Apr 18, 2005 | 06:41 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: URGENT :How to LOWER boost with Tial style wastegate (oxSLEEPERxo)
i swear to god, if you cut that spring... imma fly up there and kick you in teh *****
i may not be your daddy, but i'll whip your *** just like your daddy
Old Apr 18, 2005 | 06:45 PM
BLANKS143's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">i swear to god, if you cut that spring... imma fly up there and kick you in teh *****
i may not be your daddy, but i'll whip your *** just like your daddy</TD></TR></TABLE>
lmfao!
Old Apr 18, 2005 | 06:52 PM
this is the funniest shiet i heard today lol
Old Apr 18, 2005 | 06:54 PM
HiProfile's Avatar
Absolultely you can cut the spring. You'll love the results - waaaAAAAHH-BANG!
I'm no pychic, but I'm pretty sure that the tunner would rather have you cancel rather then blow your motor on his dyno. Not just because of the rep it gives him, but 3.5 quarts of oil isn't fun to clean up, esspecially when it gets in the rollers.
**** happens to cause delays, the tuner should know that. Maybe you should CALL him and see if they have any springs they can tune with? If the car is worth it to dyno tune it, you won't take shortcuts.
Old Apr 18, 2005 | 07:15 PM
Blown90hatcH's Avatar
Default Re: URGENT :How to LOWER boost with Tial style wastegate (HiProfile)
Should have been more prepared. If you were on a waiting list, plenty of time to prepare for this. Better buy some race gas and do your race gas tune tomorrow.
Old Apr 18, 2005 | 07:33 PM
93turbo16's Avatar
We cut the spring on a friends kit, because of incredible boost creep. It has been like that for about a year. Come kick me in the *****... when I tune your car... haha
J337_UNIT's Avatar
If your friend has the big blue spring thats 14.5 psi. If its the smaller blue spring then its the 8.7. Yes you can cut the spring, but you dont know what youll be boosting , until you try it.
Old Apr 18, 2005 | 07:41 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: URGENT :How to LOWER boost with Tial style wastegate (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">
We cut the spring on a friends kit, because of incredible boost creep. It has been like that for about a year. Come kick me in the *****... when I tune your car... haha </TD></TR></TABLE>
you have to have ***** before i can kick them
Old Apr 18, 2005 | 07:46 PM
93turbo16's Avatar
you have to have ***** before i can kick them</TD></TR></TABLE>
But if you cut the spring drastically, I am with everyone else on this one. Just wait it out man.
Old Apr 18, 2005 | 07:52 PM
SHystrdyGSRtdy's Avatar
lol man.. i don't even know why i bother... everyone has told you not to cut the spring already and you still insist on doing it... well if that's the case.. go for it.. make sure you take before pics of you happy and after when your motor has blown on you..
Old Apr 18, 2005 | 07:57 PM
Default Re: URGENT :How to LOWER boost with Tial style wastegate (SHystrdyGSRtdy)
nonono this isint for my car,,
its a friend,, worst case hes going to buy a new wastegate on the spot since the tunner dosent just want to sell him the spring...
wish me luck tomo.. ill post some dyno charts!
Old Apr 19, 2005 | 08:14 AM
done's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATgrills.com &raquo;</TD></TR><TR><TD CLASS="quote">nonono this isint for my car,,
wish me luck tomo.. ill post some dyno charts!</TD></TR></TABLE>
that is fuking ho do ****!!!!!!!!!!!!!!HHAHAHA
Old Apr 19, 2005 | 08:32 AM
11psiTurboSI's Avatar
Default Re: URGENT :How to LOWER boost with Tial style wastegate (Jordo)
keep us posted
Old Apr 19, 2005 | 08:41 AM
twkdCD595's Avatar
Default Re: URGENT :How to LOWER boost with Tial style wastegate (11psiTurboSI)
no one in your area has a spring you can buy seperate or borrow to use... what a bummer... too bad your not closer... I would definately take mine out for a boosted friend to use, in a heart beat.
good luck... hope you find a spring or something works out!
