Support for the turbo and manifold
Old Apr 18, 2005 | 05:04 PM
_Cyclone_'s Avatar
Default Support for the turbo and manifold
I didn't notice any places on my turbo or manifold to bolt it up for support. I noticed the factory exhaust manifold has three points for support, and the turbo is considerably heavier than the stock manifold. I was thinking this should be supported too, what should I do?
Old Apr 18, 2005 | 07:09 PM
HiProfile's Avatar
Default Re: Support for the turbo and manifold (CycloneBlue_1.6EL)
I'm assuming its cast iron? It really doesn't need any bracing - the stock mani uses the holes for the heatsheild. The bracing itself is typcally welded to the mani. Its the long tubular mani's that really need bracing - a lot more leverage is put on them compaired to a short cast or log maniold.
Basicly if it looks stronger than a ssautocrap manifold, it will last at least 100 miles Even some ssac's w/o bracing have been known to last at few thou miles w/o cracking.
Old Apr 18, 2005 | 07:25 PM
BLANKS143's Avatar
get a flex pipe in the dp and you should be fine.
Old Apr 18, 2005 | 07:43 PM
Evanmb44's Avatar
Default Re: (BoostedB20Z)
get a neukin manifold. that thing is beefy
Old Apr 19, 2005 | 04:25 AM
_Cyclone_'s Avatar
Default Re: Support for the turbo and manifold (HiProfile)
The manifold is cast, and looks pretty strong... I was more concerned about the added weight on the cylinder head and the studs.
black_99SI
Jun 12, 2008 11:23 AM
fin781
Dec 13, 2007 12:51 PM
lkailburn
Welding / Fabrication
Jul 31, 2005 11:57 AM
Wicked671
Mar 29, 2003 12:12 AM
