Experience with Traction Bars (wheelie bars)
Old Apr 18, 2005 | 04:17 PM
QCKGSR's Avatar
Default Experience with Traction Bars (wheelie bars)
Just wondering if anyone has some experience with what is a good height to start with when tuning the car at the track? rear coilover is a strange enginnering 7 way adj, with 450lb springs any info will be appreciated!
Old Apr 18, 2005 | 08:01 PM
lugnuts's Avatar
Default Re: Experience with Traction Bars (QCKGSR)
450 lb rear springs? thats high for a wheelie bar setup....
try a lot of rebound in the shocks
Old Apr 19, 2005 | 05:30 AM
lovitalracer's Avatar
Default Re: Experience with Traction Bars (lugnuts)
I have 150 LB spring with QA1 and they work really good . My Bar is also 65 inches from the rear bumper . Chech my sig. for pics
Old Apr 19, 2005 | 04:36 PM
QCKGSR's Avatar
Default Re: Experience with Traction Bars (lovitalracer)
yea i guess the 450lb springs maybe to hard? the bars dont even seem to hit form launch. do the wheels on the bars touch the track the whole time? and what height do they need to be run?
Old Apr 19, 2005 | 09:07 PM
b18c1ex's Avatar
correct me if im wrong but i thought that the "Wheelie bars" were for pre loading the front suspension to help elininate weight transfer by removing a slight amount of weight off the rear tires and loading that weight on the front tires
let me know im just a stoopid street racer
Old Apr 20, 2005 | 08:41 AM
Default Re: Experience with Traction Bars (b18c1ex)
I think NHRA regulation is 1 inch off the ground , but I seen it touch the ground on most accassion . I run mine 1 inch to 1/2 inch off the ground .
Yes and that does keep the wieght transfer off the back .
Old Apr 21, 2005 | 04:29 PM
QCKGSR's Avatar
i had originally set the height at 1/2" . The first run the wheel got destroyed, thery were the roller bearing wheel with the rubber tread, since then i have switched to a roller bearing plastic wheel, made 5 passes and they arent showing any wear! currently the bars are 1.250 off the track, they didnt seem to actually hit? i guess that is why i only went 1.71 in the 60 ft
Old Apr 21, 2005 | 04:44 PM
lugnuts's Avatar
nobody runs them that high.... also they need to be stiff.... use them to pick up the back end of the car, if they bend a lot thats bad. Make sure the wheels are square with the rear of the car... the "wheeleze" orange wheels are the best, 145 but worth it.
Old Apr 25, 2005 | 09:07 PM
Hondog's Avatar
what sort of 60ft's do you run with the 150lb springs and wheelie bars??
Old May 2, 2005 | 05:28 AM
QCKGSR's Avatar
Default Re: Experience with Traction Bars (Hondog)
with 450 lb springs and bars 1 1/2 " off the ground, i have been 1.71 60ft, really sorry.. only built 6psi off launch
insaneconceptz
May 19, 2009 08:57 PM
og asr
Suspension & Brakes
Aug 13, 2005 06:12 PM
2khb
Suspension & Brakes
Jan 9, 2005 12:01 AM
georgiajdm
30
Sep 16, 2003 08:41 PM
Prelussion
14
May 1, 2002 03:43 PM
