94+ integra Catalytic converter on 92+ civic?
Old Apr 18, 2005 | 03:41 PM
JDMkings's Avatar
Default 94+ integra Catalytic converter on 92+ civic?
just wanted to know if a Integra Cat. will fit on my EJ civic. I know 96+ civic cat. will work..but i just wanted to know about the integra. any info will help. thanks in advance
Old Mar 7, 2006 | 11:46 AM
monsterb18b's Avatar
Default Re: 94+ integra Catalytic converter on 92+ civic? (JDMkings)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMkings &raquo;</TD></TR><TR><TD CLASS="quote">just wanted to know if a Integra Cat. will fit on my EJ civic. I know 96+ civic cat. will work..but i just wanted to know about the integra. any info will help. thanks in advance</TD></TR></TABLE>
I need help with this as well.
I have a 95 coupe with a LS swap and DC headers. The muffler shop just welded a cat on for me and I want to get an OEM cat but I don't know what would work.
From what I've read dc headers have a collector of 2.5 and OEM is much 2.0.
How would I get an OEM cat to fit my DC header and to the end that connects to the exhuast?
Old Mar 7, 2006 | 12:09 PM
Ash81's Avatar
Default Re: 94+ integra Catalytic converter on 92+ civic? (monsterb18b)
try using your 94 o.e.m cat see if it fits the outlet might be too small....if thats the case EBAY is your friend get one off of there 2.25 inlet and 2.5 outlet the price is around $50 or less and the quality of the welding is pretty good.
Old Mar 7, 2006 | 12:20 PM
unknown0001's Avatar
Default Re: 94+ integra Catalytic converter on 92+ civic? (Ash81)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ash81 &raquo;</TD></TR><TR><TD CLASS="quote">try using your 94 o.e.m cat see if it fits the outlet might be too small....if thats the case EBAY is your friend get one off of there 2.25 inlet and 2.5 outlet the price is around $50 or less and the quality of the welding is pretty good.</TD></TR></TABLE>
For 50 bucks your buying a staright through pipe/test pipe/resinator.
You can't buy a catalytic converter for 50 bucks.
the JDM ITR cat has an inlet and outlet of I belive 2.25"...perfect for any NA engine setup.
Stock USDM ITR cat has an inlet of 2.25 and outlet of 1.75.
Either get the JDM ITR cat or buy a 2.50 or 2.25" high flow cat from maganflow/carsound and use that.
Old Mar 7, 2006 | 01:47 PM
Default Re: 94+ integra Catalytic converter on 92+ civic? (Mr.RHTuner)
Thanks
94integrals
Apr 2, 2010 03:57 PM
94integrals
Apr 2, 2010 06:25 AM
kyden
May 13, 2008 07:38 AM
THE94GSR
Oct 26, 2003 09:23 AM
