ST front sway won't line up.
Old Apr 18, 2005 | 03:33 PM
typhoon's Avatar
Default ST front sway won't line up.
Anybody installed the ST front sway for a 90-97 accord. the holes don't seem to want to line up on my CB7. From what I understand this will cause the bushings to wear out fast. also the end of the bar seems to come way to close to the damper fork. Has anyone put this on their accord before, and how hard was it to get on. I also understand you need to load the suspension to get it to fit. even so the holes don't seem to line up.
any help would be great. I hope I attached these photos right
Old Apr 19, 2005 | 01:48 AM
typhoon's Avatar
Default Re: ST front sway won't line up. (typhoon)
Hasn't anybody put an ST front sway bar on an accord?
Old Apr 19, 2005 | 09:07 AM
uncle_el's Avatar
i didn't do mine personally, i had it installed at a shop. a friend of mine also had his done at a shop. at a shop the cars were put on a lift. from looking at the pics you provided, all i can think of at this point is that the car is not being lifted enough, or not being lifted on both sides at the same time.
Old Apr 19, 2005 | 09:11 AM
typhoon's Avatar
Default Re: ST front sway won't line up. (uncle_el)
They loaded the suspension until the upper control arm was hitting the fender. Still no dice. It looks as if the bar is like 3/4" too long on both sides. Weird.
Modified by typhoon at 12:37 PM 4/19/2005
Old Apr 19, 2005 | 09:41 AM
D21X's Avatar
dont u need the bushing that goes there along with the long bolt???
Old Apr 19, 2005 | 10:35 AM
Nick H's Avatar
New User
Default Re: ST front sway won't line up. (D21X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D21X &raquo;</TD></TR><TR><TD CLASS="quote">dont u need the bushing that goes there along with the long bolt???</TD></TR></TABLE>
i think that's only for the rear...
Old Apr 19, 2005 | 10:50 AM
maivietla's Avatar
Default Re: ST front sway won't line up. (Nick H)
What i think u have to do is put some pressure on the sway and make it fit... because when i changed mine this problem occured... i used the coil spring to compress it , maybe u can loose out the nut in side and put some pressure into it..
Old Apr 19, 2005 | 11:09 AM
typhoon's Avatar
Of course.
Thats where they would go if the holes lined up allowing the bolt through.
Old Apr 19, 2005 | 12:14 PM
Daniel M.'s Avatar
This is the bar fitted on my Accord.
Old Apr 19, 2005 | 01:17 PM
typhoon's Avatar
Default Re: ST front sway won't line up. (Daniel M.)
Thanks man.
It looks like your bar lines up enough to get the bolt through. Was it hard to do? Yours is a 5th gen and mines a 4th. I know that it's supposed to fit both. My bar still looks too long conpaired to where yours ends. as mine is hitting against the damper fork, and yours looks like it has some clearence.
Whoops not a 5th gen, Euro Accord.
Hmmm.... Not sure what to make of that.
Old Apr 23, 2005 | 02:41 PM
Daniel M.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typhoon &raquo;</TD></TR><TR><TD CLASS="quote">Thanks man.
Hmmm.... Not sure what to make of that.</TD></TR></TABLE>
My Accord is the European 5th gen Accord, different body, but same chasis.
My ST bars are for the 5th gen USA Accord.
They fitted almost perfectly. The center curve of the front bar sometimes rubs against the boody.
stallinrawlings
Suspension & Brakes
Jun 17, 2018 01:13 PM
Gnate
Nov 9, 2014 01:12 PM
gsr camel
Sep 23, 2007 04:16 PM
honda93
Jul 3, 2005 04:53 PM
RJD2
Jan 31, 2005 03:34 PM
