Got my 40-pt inspection, got some questions (brakes, o2 sensors, gaskets, 90k)
Old Apr 18, 2005 | 03:12 PM
sup gurl's Avatar
Default Got my 40-pt inspection, got some questions (brakes, o2 sensors, gaskets, 90k)
Alright so I got my free 40 point inspection today.
Got three things "wrong"
CEL- which I knew- Both O2 sensors and harnesses are bad, they way 860 dollars to fix, should I try somewhere else? That seems insanely high.
Brakes- They said my back brakes have 10% left, should I just replace the back or front too? They didnt say how much was left in the front.
Lastly- they said my valve cover was "starting to seep oil." Is this a BIG deal? He said the gasket was getting dry or somethin', said it would only be like 150 bucks to fix, is this a big deal? Should I get this fixed ASAP?
Thanks for the help
OH YEAH!
I got 90k service comin up, HONDA wants 1300 dollars!!! At Tires Plus they only was like 350+ tax to do the same thing....where do you recommend for someone with NOT much cash, ha
Old Apr 18, 2005 | 03:33 PM
A Blue Lude's Avatar
Default Re: Got my 40-pt inspection, got some questions (egpbb6)
If you're at all worried about saving cash, don't go near a stealership...
Old Apr 18, 2005 | 04:17 PM
clemsoncb7's Avatar
Default Re: Got my 40-pt inspection, got some questions (Featherfire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Featherfire &raquo;</TD></TR><TR><TD CLASS="quote">If you're at all worried about saving cash, don't go near a stealership...</TD></TR></TABLE>
Word, that is freakin ridiculous. Those o2 sensors you can do yourself, may take a while but would only be about $30. Brakes are easy to do yourself too, and the valve cover, just pick one up from ebay for like $100, and a new gasket, $10, and you should be good to go!
Old Apr 18, 2005 | 06:40 PM
RHD_BB4T's Avatar
Default Re: Got my 40-pt inspection, got some questions (maxvtec7500)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxvtec7500 &raquo;</TD></TR><TR><TD CLASS="quote">
Word, that is freakin ridiculous. Those o2 sensors you can do yourself, may take a while but would only be about $30. Brakes are easy to do yourself too, and the valve cover, just pick one up from ebay for like $100, and a new gasket, $10, and you should be good to go!</TD></TR></TABLE>
Why would you even need a new VALVE COVER? I say replace the gasket and be done with it...
Old Apr 18, 2005 | 06:47 PM
AndyD's Avatar
Yup, what they did to you is the WHOLE reason for the FREE 40 pt. inspection.
O2 sensors are easy to replace. The sensor itself is what costs some money.
Brake pads are SOOO freakin easy to replace.
The valve cover gasket is easy to change. The main thing to watch out for is tightening the valve cover bolts too hard. There is the possibility of braking the treaded stud.
I HATE ****** mechanics. They make so much money off these easy issues. Plus, many lie.
Old Apr 18, 2005 | 07:08 PM
v4lu3s's Avatar
RTFM
first off dont get anythign done at the dealer, and DONT go to "tires plus"
find a good small honda specialty shop.
have them look at the thigns that ar eissues and handle the 90k service. it will cost mroe than the tire place, but it will be doen by someone who knows hondas not a tire changer and brake guy.
Old Apr 18, 2005 | 07:58 PM
djSALIX's Avatar
Haha check out my car's sheet.
Done @ Liberty Honda in Hartford, CT.
Vehicle:
1992 Honda Prelude S
191400 Miles
5-Speed
Requires Attention:
Winshield washers & wipers
Parking Brake
Body (Paint, Trim, Damage) (see https://honda-tech.com/zerothread?id=1169495 for damage)
Antenna
Wiper blades (front & rear)
CV-joint boots
Engine & transmission leaks
Tires condition & pressure (including spare)
Priority Items:
Parking Light $28.00
Antenna Mast Missing $478.00
Radiator rotted $620.00
Valve Cover Gasket $99.00
Axle boots $375.00
2 Tires/Alignment $370.00
Oil Leaks, must degrease engine $82.50
Body Rot
Total: $2052.50
Wow.
EDIT: I only did it because it was free and I needed to know exactly what was wrong with the car. This helps me out a great deal.
Old Apr 18, 2005 | 08:47 PM
mkazm83's Avatar
Im getting mine done tomoorow ill let you guys know how it goes.
Old Apr 18, 2005 | 08:58 PM
xludexgenx5's Avatar
Default Re: Got my 40-pt inspection, got some questions (djSALIX)
man thoose prices are insanely high, DIY and save.
Old Apr 18, 2005 | 09:17 PM
SpeedMachine's Avatar
Default Re: Got my 40-pt inspection, got some questions (xludexgenx5)
run as fast as you can
Old Apr 18, 2005 | 10:40 PM
OEM_ASSASSIN's Avatar
Default Re: Got my 40-pt inspection, got some questions (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">
I HATE ****** mechanics. They make so much money off these easy issues. Plus, many lie.</TD></TR></TABLE>
That was the gheyest thing ever. I only gave it like 11 ft/lbs and it snapped, the last one too. I had to wait two days to get one.
I think for the gasket for the valve cover and the spark plug grommet gasket things cost me a total of $17 from Honda. Replace the spark plug ones too. I don't know how they can even charge $150 for that.
The O2 Sensor thing sounds extremely high too. I would get a second opinion if you cannot do it yourself.
Old Apr 19, 2005 | 08:20 AM
eluder33's Avatar
Default Re: Got my 40-pt inspection, got some questions (OEM_ASSASSIN)
Priority Items:
Axle boots $375.00
Body Rot
Total: $2052.50
yell fock joo and run the hell outta there
Old Apr 19, 2005 | 08:29 AM
Unlimitationz's Avatar
Default Re: Got my 40-pt inspection, got some questions (matty c)
What is the highest point inspection they have? 90 points? And what else do they check if they do a 90 point one?
Old Apr 19, 2005 | 11:13 AM
98TypeSH's Avatar
Default Re: Got my 40-pt inspection, got some questions (AznUnlimitationz)
the valvecover bolts spec is 8 ft lbs. 11 ftlbs would bust them yes.
Dont need a tq wrench to tighten them. Just do it snug.
Old Apr 19, 2005 | 12:06 PM
pentaq's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djSALIX &raquo;</TD></TR><TR><TD CLASS="quote">
Priority Items:
Axle boots $375.00
Body Rot
Total: $2052.50 </TD></TR></TABLE>
This is ******* ridiculous.
Old Apr 19, 2005 | 01:31 PM
AndyD's Avatar
Default Re: Got my 40-pt inspection, got some questions (pentaq)
Man, I am thinking about havign them do this 40 pt. inspection when I get my seatbelts serviced under warranty. I would like to see what they tell me is wrong with my car.
Here are the items I've changed. There are a few others that I failed to mention.
Just to note a few upgrades I did:
-JDM swap with ALL the maintance done, with an Exedy race clutch and ltw flywheel. Hondata IM gasket too
-Replaced front calipers with Legend calipers and VTEC rotors. New brakes too
-New radiator
-Forbidden Short shifter
-Tein Basic coilovers
-New tires
-New battery
-Dynamatted almost the entire car. (Make sure you atleast do the driver's side door)
-Pulled all the trunk interior, cleaned, replaced
-Pull ALL the interior to clean carpet, seats, and door panels.
-Got rid A LOT of squeeks.
-New stereo and speakers
-Fixed cracked door handle trim. Painted button with red top too. Looks new again
-Fixed rubber seals throughout the car
-Replaced rear speaker covers. They were faded....BAD!!
-Fixed my 4WS issue
-Fixed climate control issue
-Replaced axles
-Replaced ENTIRE exhaust system (OEM header, Carsound car, Thermal cat-back)
-Cleaned the entire engine bay when I swapped motors. I painted many brackets too
-Replaced corner light bulbs with yellow bulbs
-Replaced AC compressor and fixed AC
-New clutch master and slave cylinder
-Fixed the rear defogger (plug was unplugged)
Old Apr 19, 2005 | 02:20 PM
sup gurl's Avatar
Hahahah wow
So... I should just buy brake pads and a gasket and do it myself?
If so, are Axxis pads good? And should I just get the gasket from Honda or what?
Old Apr 19, 2005 | 02:51 PM
pentaq's Avatar
Default Re: (egpbb6)
Axxis is OK, I have recently bought the whole set of gaskets for a valve cover for 33$ as I remember correctly- genuine Honda
Old Apr 19, 2005 | 03:31 PM
5spdIntegra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egpbb6 &raquo;</TD></TR><TR><TD CLASS="quote">Hahahah wow
If so, are Axxis pads good? And should I just get the gasket from Honda or what?</TD></TR></TABLE>
Oh man please do it yourself!!!! You can find DIY's on almost anything and you have 1000's of people on here that can help you through every step. I just changed an H23 valve cover gasket with all the spark plug gaskets as well. One of the easiest things you can do!!!
Old Apr 19, 2005 | 04:42 PM
sup gurl's Avatar
Default Re: (5spdIntegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5spdIntegra &raquo;</TD></TR><TR><TD CLASS="quote">
Oh man please do it yourself!!!! You can find DIY's on almost anything and you have 1000's of people on here that can help you through every step. I just changed an H23 valve cover gasket with all the spark plug gaskets as well. One of the easiest things you can do!!!</TD></TR></TABLE>
PM me with DIY for valve cover gasket!!
Old Apr 20, 2005 | 09:15 AM
Hawkze_2.3's Avatar
PM me with DIY for valve cover gasket!! </TD></TR></TABLE>
Take off the valve cover, pull off the old gasket and replace it with the new one. It's that easy, just be carefull with the valve cover studs as said before.
Old Apr 20, 2005 | 06:33 PM
s13_240sx_92's Avatar
Everything there you can do yourself. Get yourself a decent tool kit and a Helms manual and you'll be in business. HT for when you run into problems.
Those prices are criminal.
Old Apr 20, 2005 | 06:38 PM
esca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">Man, I am thinking about havign them do this 40 pt. inspection when I get my seatbelts serviced under warranty. I would like to see what they tell me is wrong with my car.
holay crap i should just give my car to andyd and all my problems will be solved!!!!
Old Apr 20, 2005 | 06:53 PM
Lewdin' Incognito's Avatar
Your 40-pt inpection:
Axle boots $375.00
Body Rot
Total: $2052.50
eBay:
Parking Light $6.00
Antenna Mast Missing $20.99
Radiator rotted $104.00
Valve Cover Gasket $14.00
complete axles $60.00
2 Tires/Alignment $100.00 + alignment($40?)
Oil Leaks, must degrease engine - ??? wash it....$3 at car wash - pressure washer
Body Rot - eh, "HondaBond" lol
Total: $350 + s/h (+ hondabond)
I just saved you at least $1600.
Tell you what, buy off eBay....send me $800, and you still saved money!
Want my address?
Old Apr 20, 2005 | 07:34 PM
djSALIX's Avatar
Default Re: Got my 40-pt inspection, got some questions (neoluder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neoluder &raquo;</TD></TR><TR><TD CLASS="quote">Your 40-pt inpection:
Axle boots $375.00
Body Rot
Total: $2052.50
eBay:
Parking Light $6.00
Want my address? </TD></TR></TABLE>
That'd be great if I was actually going to do it with the dealership. But I found everything I needed for less than what you quoted me
