GS-R compression 240-235-230-235.......Are these numbers right ???
Old Apr 18, 2005 | 02:43 PM
MikeTV
Guest
Posts: n/a
Default GS-R compression 240-235-230-235.......Are these numbers right ???
I tested my 195,000 miles gs-r a few days ago and the results were 240-235-230-235......the weird thing is that I tested it 2 months ago also, and I came out with 195-195-195-190...I always thought that the highest compression for a gs-r motor was like 225.........is that the case or can a gs-rs compression really be 240 ? Allso, why would the numbers change for the better instead of for the worse ??
Old Apr 18, 2005 | 02:54 PM
sabotage7's Avatar
Default Re: GS-R compression 240-235-230-235.......Are these numbers right ???
my 94 gsr tested 240-240-240-240 a couple months ago. thats weird that yours changed that much though. have you done anything different since then?
Old Apr 18, 2005 | 03:01 PM
AlxSiR7's Avatar
Default Re: GS-R compression 240-235-230-235.......Are these numbers right ??? (sabotage7)
thats pretty damn good.. my jdm gsr motor with about 40k on it has 225 straight across. seems kinda odd that yours would go up though... id do it again.
Old Apr 18, 2005 | 03:02 PM
MikeTV
Guest
Posts: n/a
the only thing that I've done since then was take apart the throttle body and clean it, as well as clean the inside of the intake manifold......I also changed sparkplugs about 2 weeks ago....
Old Apr 18, 2005 | 03:13 PM
Rory Breaker's Avatar
Default Re: GS-R compression 240-235-230-235.......Are these numbers right ??? (Eclipse spanker)
Were you at WOT the first time?
Old Apr 18, 2005 | 03:39 PM
MikeTV
Guest
Posts: n/a
Default Re: GS-R compression 240-235-230-235.......Are these numbers right ??? (Rory Breaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rory Breaker &raquo;</TD></TR><TR><TD CLASS="quote">Were you at WOT the first time?</TD></TR></TABLE>
I was not at WOT the first time. The second time I was though.....would that be the reason ?
Old Apr 18, 2005 | 04:14 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eclipse spanker &raquo;</TD></TR><TR><TD CLASS="quote">
I was not at WOT the first time. The second time I was though.....would that be the reason ?</TD></TR></TABLE>
yes
Old Apr 18, 2005 | 04:28 PM
airplan727's Avatar
280 is standard and 180 is min. Those are pretty good for 195,000
Old Apr 18, 2005 | 05:16 PM
Default Re: GS-R compression 240-235-230-235.......Are these numbers right ??? (sleeperciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperciv &raquo;</TD></TR><TR><TD CLASS="quote">
yes</TD></TR></TABLE>
Old Apr 18, 2005 | 06:06 PM
MikeTV
Guest
Posts: n/a
so if thats the case, how can a motor that has almost 200,000 miles have compression of 240-235-230-235 ?? Carbon buildup maybe ?
Old Apr 18, 2005 | 06:14 PM
Good engineering. And yes, carbon buildup would increase your C/R slightly, but the main thing your looking at is variance between the numbers. And yours is solid.
I have 124k on the clock, 53k boosted, and my compression is 230/240's across. &lt;knock on wood&gt;These cars just keep on tickin man.
Your compression numbers dont reflect your overall health however. You could have great compression and shitty leakdown %'s. It definitely is a good sign though.
Old Apr 18, 2005 | 09:25 PM
MikeTV
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rory Breaker &raquo;</TD></TR><TR><TD CLASS="quote">Good engineering. And yes, carbon buildup would increase your C/R slightly, but the main thing your looking at is variance between the numbers. And yours is solid.
Your compression numbers dont reflect your overall health however. You could have great compression and shitty leakdown %'s. It definitely is a good sign though.</TD></TR></TABLE>
ok , cool thanks alot man
MikeTV
Guest
Posts: n/a
Just curious, how many lbs of bost have you been running for 53k ?
Old Apr 19, 2005 | 04:19 AM
Spec R's Avatar
its industry standard to pull all the plugs out. saves you the WOT stuff.
Old Apr 19, 2005 | 05:49 AM
hott-nix's Avatar
Default Re: (airplan727)
if 280 is standard, then it's almost time for me to do a rebuild
i got 185,185,185,185 the last time i checked mine. i was under the impression that 200 across was standard
Old Apr 19, 2005 | 05:54 AM
Default Re: (hott-nix)
280 def isnt standard, thats WAY high. I forget the exact specs, but 185 is on the low side. Are you sure you were WOT?
Ive been anywhere between 6-11PSI throughout that time, but I would say the majority was spent at a solid 6-8PSI daily. I was JRSC'd for 40kish and turbo'd for the rest.
A lot of those miles were on the shitty JR FMU setup as well, and it was running WAY lean up top. These motors are just incredible, especially with good tuning. I couldnt ask for any more, and Im happy every day she fires up and runs hard
Old Apr 19, 2005 | 06:27 AM
simon98h22's Avatar
Default Re: (Rory Breaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rory Breaker &raquo;</TD></TR><TR><TD CLASS="quote">280 def isnt standard, thats WAY high</TD></TR></TABLE>
Agreed
hawaiieg6
Jul 15, 2009 08:57 AM
Dev15Bizz
May 2, 2007 08:19 PM
bustdgst
Jan 26, 2007 01:05 AM
Project_EK
10
Jun 16, 2005 09:18 PM
