Garage Sale: Pistons, Rods, Fuel Rails, Regulators, Starters, Alts, Tb's...
Alright. I am moving soon and I really don't want to have to take all this with me. Please, help me clean up the garage!
First up, we have some throttle bodies. Two on the left are for a B series, the three on the right are 58mm LS throttle bodies. One is missing a butterfly, the rest are as pictured. I do not believe ANY have TPS's on them. Good cores if you want to get yours bored out. Please keep in mind the 58 mm's are first gen and use firewall mounted map sensors. MAKE OFFER
Next up are some fuel rails. The ones on the left are for a D series, the ones on the top right are B series. Not sure about the two below those, maybe F series? Some include regulators, others don't. I also have three misc fuel regulators also. Not sure what they came from, good for those modding for a B&M. MAKE OFFER
Next up. Alternators and starters. All the starters are B series, the one alt on the left is D series, the other is an OBD-2 B series. MAKE OFFER
Now the fun part. Pistons. The top row is a set of pistons and rods from a JDM B16a, first gen. Unknown milegae, I pulled them in favor of something else. Good shape.
To the left, set of GSR pistons. Not sure of mileage again, lots of carbon build up, should be cleaned. Good shape.
Bottom is a set of PR3 (b16) rods with aftermarket forged pistons for boost. I am not sure of the brand they are. One was "knicked" when it was pressed on the rod (I assume), I didn't install these. I removed them from a setup I built and have no use for them. The one that was knicked is still usable. Came from a running car, no noises or anything like that. The little "dots" you see on the top of the piston is where I marked them for cylinder numbers before they were removed. Nothing to worry about.
Some of the pistons include rings, some of the rods have bearings. I make no gaurantee for the condition of either the rings or the bearings. I would highly recommend you replace the rings and the bearings, do not reuse these. Shoot me offers on everything you see here. I have an idea what this stuff is worth, so please no rediculously low offers.
Anyone? Make offers. I'm not looking to get a fortune for this stuff. Just would rather see it go to use then the garbage can.
