tach problem
Old Apr 18, 2005 | 01:53 PM
Spins's Avatar
Default tach problem
95 hatch with b18c swap.
Problem with tach is at idle the tach sets at zero. When I rev or drive the tach moves but is incorrect. The engine used to rev to 8300rpm now the tach shows around 8000rpm when the limiter kicks in. I'm sure the engine is reving to the correct rpm just the tach is off. I started noticing the tach would read low at idle sometimes. Now at idle it sets at zero. I removed the distributor cap, everything looks clean. I replaced the dist. rotor and plug wires. They where old and showing signs of wear. This didn't help. I unplugged the 2 wire harnesses located behind the distributor they look clean. I sprays some WD-40 in the harness. No difference. Any ideas? I did search.
Old Apr 18, 2005 | 01:59 PM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: tach problem (Spins)
At idle does the needle move, or does it stayin the same place as when the car is off?
Old Apr 18, 2005 | 02:01 PM
Spins's Avatar
Default Re: tach problem (walker111)
It just lays there. I read if the needle jumps it means the coil is going bad.Correct?
Rotten Egg
Aug 24, 2009 10:20 PM
lexusgui
Jul 27, 2008 07:54 PM
wood 1
11
Jan 4, 2008 04:45 PM
vinuneuro
Mar 28, 2005 11:41 PM
