How do you change turn signal indicator arm / Head light switch? Help
Old Apr 18, 2005 | 11:00 AM
way2much's Avatar
Default How do you change turn signal indicator arm / Head light switch? Help
Okay I tried searching so please...I am trying to change the Headlight switch / turn signal arm on the steering column...just wondering how to do it? Are there any articles, pictures, or tips and what to watch out for?
Any help would be apreciated
Thanks
this is for a 90 Civic SI
Old Apr 18, 2005 | 11:36 AM
mahatma's Avatar
Default Re: How do you change turn signal indicator arm / Head light switch? Help (way2much)
I did this not long ago. Just remove the steering wheel and the plastic column covers, unplug all connections, then the whole assembly should slide out as one piece (picture a seagull).
If you're swapping out individual switches from that assembly, be sure to note the alignment/placement of the sliding pieces within the switch when you remove the original. It's easy to confuse, but it'll make sense once you're in there.
And be VERY careful with the each switch's retaining clips, they're fragile.
Old Apr 19, 2005 | 09:48 AM
way2much's Avatar
Default Re: How do you change turn signal indicator arm / Head light switch? Help (mahatma)
mahatma
thanks for the reply
Do you really have to remove the steering wheel? That seems like alot just to get to the assembly.
I am not swapping out individual swithces from the assembly...i was able to buy the whole arm/assembly.
what is this switch's retaining clipse you speak of? Does it only pertain to if you replace the individual switches or also the swapping out the whole assembly. I will try to email you a pix of the assembly
any body have pictures or links to this?
Old Apr 19, 2005 | 12:41 PM
mahatma's Avatar
The clips only come into play when you're pulling individual switches out, you won't have to worry about those.
Sorry no pics though....and yeah, unfortunately you have to remove the steering wheel, but it's mo easy.
Old Apr 19, 2005 | 12:44 PM
Exempt's Avatar
Yea u have to remove the steering wheel... And then remove the 2 covers on the collumb, then theres like 2 screws that hold the switch on, unscrew those, and there is a little hole, u have to use a flathead, and carefully pry between the switch and where it mounts by that little hole (because there is a small piece that snaps into place in that hole, u have to lift it up and then slide the switch out)...
alex14
Feb 22, 2011 08:48 PM
G2_Fella
Aug 25, 2010 12:40 PM
gpower07
Oct 20, 2009 06:28 AM
FireMedic
May 23, 2003 04:26 PM
pablo_max
Nov 12, 2002 04:02 PM
