"Burned" 3/4 of a quart of oil in EP3 - Concerned?
Old Apr 18, 2005 | 10:15 AM
andyep3's Avatar
Default "Burned" 3/4 of a quart of oil in EP3 - Concerned?
Changed my oil this week after going about 4k since the last one (at least). Had been using Mobil 1 0w-20 but it seems that they discontinued that, so I switched over to 5w-20.
When I was pouring out the old oil into a container (gallon jug), noticed I didn't even fill it up. So I was probably missing 1/2 -3/4 of a quart. Should I be concerned?
I know the K20A3 has eaten plenty of oil, but I'm at 29k miles and haven't had this issue up until now. Could it just be from the extended miles and low viscosity oil I was using? How often should I check it to see if I'm missing any - every fill up?
Old Apr 18, 2005 | 10:39 AM
Sephiroth's Avatar
Default Re: "Burned" 3/4 of a quart of oil in EP3 - Concerned? (andyep3)
I wouldnt be too concerned.. you believe its a little low based on the 4k? Did you do the last oil change before you switched to 5w20? If so didnt you do it at the same distance?
Old Apr 18, 2005 | 10:41 AM
kung fu grip's Avatar
my ep ate oil BEFORE 15k miles, then none.
Old Apr 18, 2005 | 11:47 AM
andyep3's Avatar
Default Re: "Burned" 3/4 of a quart of oil in EP3 - Concerned? (Sephiroth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sephiroth &raquo;</TD></TR><TR><TD CLASS="quote">I wouldnt be too concerned.. you believe its a little low based on the 4k? Did you do the last oil change before you switched to 5w20? If so didnt you do it at the same distance? </TD></TR></TABLE>
Yes, I've done all but the first 2 oil changes myself.
I probably changed it at 3k or 3.5k last time. Definitely went over 4k this time, methinks.
Old Apr 20, 2005 | 06:32 AM
RemerLex11's Avatar
1/2 - 3/4 HA you're a lightweight and to answer your question...NO
Old Apr 20, 2005 | 06:53 AM
andyep3's Avatar
Default Re: "Burned" 3/4 of a quart of oil in EP3 - Concerned? (Matt5745767)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matt5745767 &raquo;</TD></TR><TR><TD CLASS="quote">1/2 - 3/4 HA you're a lightweight and to answer your question...NO</TD></TR></TABLE>
That's what I figured - wasn't that big of a deal/was just due to hard driving/going aways before the change, but I wanted to double check.
Thanks fellas.
p3terson17
Honda Civic (2006 - 2015)
30
Jan 21, 2009 08:12 PM
HYREV2NR
Honda Fit
80
Oct 6, 2008 02:00 PM
d3xt3r19
Dec 5, 2007 05:30 PM
Bulli Kid
28
Sep 25, 2007 01:31 PM
Steve26
Jul 29, 2004 05:09 PM
