Antifreeze????
should be filled to the top of the radiator and some in the reserve. The reason you put 50/50 water and antifreeze is because it circulate the heat better. If you just put straight antifreeze it wouldn't have much of an effect. -Jon
Yeah, it just pulls out from the top. You sort of need to get a non-leaking radiator, otherwise there could be problems. The cooling system depends on pressurizing the system to keep the coolant from boiling, and a leak makes this difficult at best.
Honda coolant, which is the only coolant you should ever run by the way, comes pre-mixed 50-50. Most other coolants contain silicates in an effort to lubricate the water pump. Silicate = silicon = sand. I don't put sand in my engine.
justinwebb
23
May 6, 2009 08:24 PM
icedlee
May 15, 2005 10:21 PM
