rear disc brake conversion
Old Apr 18, 2005 | 08:58 AM
puma1077's Avatar
Default rear disc brake conversion
ok i have a 94 accord LX, it has rear drum brakes (boooo )
My friend has his 1999 Integra GSR totaled, is there anyway I could use the rear disc brakes off of the GSR and put them on my accord for the rear disc swap? Or does it have to be from an accord?
Old Apr 18, 2005 | 10:14 AM
uncle_el's Avatar
Default Re: rear disc brake conversion (puma1077)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by puma1077 &raquo;</TD></TR><TR><TD CLASS="quote">ok i have a 94 accord LX, it has rear drum brakes (boooo )
My friend has his 1999 Integra GSR totaled, is there anyway I could use the rear disc brakes off of the GSR and put them on my accord for the rear disc swap? Or does it have to be from an accord?</TD></TR></TABLE>
an integra's bolt pattern will be 4 x 100, or 5 x 114.3 (unless he did a 96 jdm itr swap, in which case it would be 4 x 114.3). so, even if the parts worked, you're front suspension would be 4 x 114.3, and the rear would be 4 x 100 or 5 x 114.3.
as i understand it, for the 5th gen accord, your best bet is to get calipers and rotors from a 5th gen accord, or 90-97 (both 4th and 5th gen) wagon.
diy rear disc conversion on a 5th gen
wwolf771177
Jan 10, 2014 06:41 AM
krt671_cb7
Mar 18, 2010 07:01 PM
accordtype R
Feb 19, 2006 12:39 PM
