Alignment issues on 6th Gen Accord Coupe EX
Old Apr 18, 2005 | 08:46 AM
jdiz45's Avatar
Default Alignment issues on 6th Gen Accord Coupe EX
I recently took my EX 4cyl in for new tires and alignment, and they told me that I have a problem with my driver's rear alignment. It made sense to me since I had backed onto a curb with it a year ago. They said it could be a bent control arm or strut. I'm not sure what to do now. Should I take it to the stealership for an alignment check, so they can tell me what's wrong? I'm sure I could change a strut or control arm, but I'm not sure how to figure out what I need. Any advice would be appreciated.
Old Apr 18, 2005 | 10:47 AM
RotaryBzzzz's Avatar
Default Re: Alignment issues on 6th Gen Accord Coupe EX (jdiz45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdiz45 &raquo;</TD></TR><TR><TD CLASS="quote">They said it could be a bent control arm or strut. I'm not sure what to do now.</TD></TR></TABLE>
Bent control arm or strut is on the magnitude of "i got into an accident".....Not "I backed in a curb".
Sounds like they're BS'ing you to upsell you.
Ask them point blank: "CAN YOU SET THE ALIGNMENT TO WITHIN FACTORY SPECS? YES OR NO?". They will probably say "well, we can get it kinda close" = means yes.
Old Apr 18, 2005 | 06:54 PM
jdiz45's Avatar
Default Re: Alignment issues on 6th Gen Accord Coupe EX (RotaryBzzzz)
They claimed they could not align it, and they were unable to deal with the problem. The guy told me I would need to take it to the dealer or body shop.
Old Apr 19, 2005 | 03:45 AM
jdiz45's Avatar
Forgot to mention, the alignment was attempted at Just Tires, where I got my tires.
Old Apr 19, 2005 | 11:26 AM
iam7head's Avatar
take your car back to justtire and tell them to do the alignment to the best they can, DEMAND to have a print out of the SPEC sheet(BEFORE alignment and AFTER alignment)
if the AFTER spec is in factory spec then you are good
If the AFTER spec is way off, which probably will be if you hit a curb or got into an accident. go replace bent/twisted suspension part that on that damaged side.
now it's your call to bring it to dealership or other place(or diy), check for damage in tie rod, control arms, etc
don't forget to get an alignmnet after you done
JDM*Teg
Suspension & Brakes
15
May 20, 2008 10:13 AM
EH6TunerDaniel
20
Jan 10, 2007 07:42 PM
jdiz45
Jul 1, 2005 03:07 AM
driftt
Aug 14, 2004 11:29 AM
illusion
Sep 5, 2002 01:23 PM
