Tube on top of valve cover...
Old Apr 18, 2005 | 07:41 AM
bboyoracle's Avatar
Default Tube on top of valve cover...
The tube that connect to your intake...can it be replaced???????
Long story short, i recieved a valve cover...was shipped poorly and that tube broke off. I have my old valve cover can i use the tube from that one??? TIA
Old Apr 18, 2005 | 07:56 AM
SuzukaBlueAP2's Avatar
Default Re: Tube on top of valve cover... (bboyoracle)
You just need the tubing? Yeah, you can replace that. Most aftermarket intakes give you some crappy nylon vaccum tubing. You can get good hose that will fit it from an auto parts store.
Old Apr 18, 2005 | 08:07 AM
bboyoracle's Avatar
Default Re: Tube on top of valve cover... (ScreaminTeg)
no i'm sorry i meant i need the metal tube that is connected to the actual valve cover
Old Apr 18, 2005 | 08:19 AM
White Smoke's Avatar
i my honda
Global Mod
I’m pretty sure its part of the manifold. As is NON-REMOVABLE/REPLACEABLE
Post up some pics... Maybe some JB Weld would do the trick?
Old Apr 18, 2005 | 04:03 PM
bboyoracle's Avatar
Default Re: Tube on top of valve cover... (White Smoke)
well looks like my only choice is to cut it off, thread the opening and have a new tube put in. Off to claims I go as well.....
G'Funk
Apr 8, 2006 05:04 AM
allmotorhatch
Mar 8, 2005 09:46 AM
