Removing Rota Center Caps
Old Apr 18, 2005 | 07:36 AM
93civicsedan's Avatar
Default Removing Rota Center Caps
I just got a set of rota slipstreams and they have the carbon fiber look center caps. How do I go about removing them? I noticed they have a few hex screws do they have to be removed? Thanks.
Old Apr 18, 2005 | 08:39 AM
JDM H23A's Avatar
Default Re: Removing Rota Center Caps (93civicsedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93civicsedan &raquo;</TD></TR><TR><TD CLASS="quote">I just got a set of rota slipstreams and they have the carbon fiber look center caps. How do I go about removing them? I noticed they have a few hex screws do they have to be removed? Thanks.</TD></TR></TABLE>
Dude...you can just pull them off with your hands It might be a little tough, so you can also use a flat-head screwdriver (just make sure you don't scratch the finish). Otherwise, take off your wheels and pop them out from the inside. Those hex-nuts aren't anything
Old Apr 18, 2005 | 05:12 PM
Default Re: Removing Rota Center Caps (JDM H23A)
thanks for the reply. the wheels arent mounted so i guess i will try to remove them again. i was using a screwdriver at first but then i saw the hex screws. i just wanted to be sure on how to remove them so i wouldnt damage them.
Old Apr 18, 2005 | 05:51 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
if the wheels are off the car, hold the wheel upright, and tap the center cap from the inside out.. it will pop right out of the wheel.
Old Apr 20, 2005 | 01:10 PM
buyer's Avatar
shoot them out with a gun!
Old Apr 20, 2005 | 01:28 PM
Mike_C's Avatar
Default Re: Removing Rota Center Caps (yaya1)
handle of a screwdriver from the backside pops em right out.
BeBe
Dec 22, 2004 01:18 PM
tekkynikality
Feb 15, 2004 04:29 PM
toddbenson
16
Jan 24, 2004 01:12 PM
J-Ro
Jun 12, 2003 09:51 AM
BlueG3Teg
Feb 16, 2002 05:34 PM
