help! broke o2 sensor in exhaust manifold!
Old Apr 18, 2005 | 06:14 AM
91integraLSVTEC's Avatar
Default help! broke o2 sensor in exhaust manifold!
one of the many problems i ran into with my car yesterday =o( i broke the 02 sensor completly off the exhaust manifold with a breaker bar. the other half is still inside. how do i take off the broken piece in the manifold? car is a 95 honda civic ex. car from hell
Old Apr 18, 2005 | 06:15 AM
jlacoy82's Avatar
71.192.16.183
Default Re: help! broke o2 sensor in exhaust manifold! (91integraLSVTEC)
Did you snap the off the bolt part, leaving just the tip of the o2 sensor and its threads in the manifold?
Old Apr 18, 2005 | 06:17 AM
Jorsher's Avatar
lol don't blame the civic.
It would be nice to know or see how much is actually left in it... Maybe you can punch the rest through, don't worry about breaking it since it's already broke, if you can't get it out the right way you might as well break it more until it goes through.
Old Apr 18, 2005 | 06:43 AM
Default Re: help! broke o2 sensor in exhaust manifold! (jlacoy82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 &raquo;</TD></TR><TR><TD CLASS="quote">Did you snap the off the bolt part, leaving just the tip of the o2 sensor and its threads in the manifold?</TD></TR></TABLE>
yes thats exactly what happened.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jorsher &raquo;</TD></TR><TR><TD CLASS="quote">lol don't blame the civic.
It would be nice to know or see how much is actually left in it... Maybe you can punch the rest through, don't worry about breaking it since it's already broke, if you can't get it out the right way you might as well break it more until it goes through.</TD></TR></TABLE>
hmm that might work but wouldnt i damage the threads? also i dont think i'll be able to punch it out, theres still a decent part of metal in there.
Cuong-nutz's Avatar
if the threaded portion is still in the EM, just extract it out and put in new one
Old Apr 18, 2005 | 06:52 AM
flood's Avatar
Default Re: help! broke o2 sensor in exhaust manifold! (Cuong-nutz)
You may need to use a fire wrench too. AKA torch to heat the hell out of it. It will come out easier that way. Actually, you may have wanted to use the "fire wrench" in the first place because it may not have broke.
Or you could run the car for a while if you dont have access to a torch.
Old Apr 18, 2005 | 06:56 AM
jlacoy82's Avatar
71.192.16.183
Default Re: help! broke o2 sensor in exhaust manifold! (flood)
Drill out the center of it, then chisel the old pieces of thread off.
Old Apr 18, 2005 | 07:03 AM
Jorsher's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91integraLSVTEC &raquo;</TD></TR><TR><TD CLASS="quote">yes thats exactly what happened.
hmm that might work but wouldnt i damage the threads? also i dont think i'll be able to punch it out, theres still a decent part of metal in there. </TD></TR></TABLE>
Yeah that's why I said it's kinda important he tell us how much is left. If there's even a little bit sticking out the top he should be able to get something and twist it out, if not he'll have to extract it like others said.
Old Apr 18, 2005 | 07:34 AM
Ninety5Ex's Avatar
when mi broke they welded a bolt to it and used a vice grip
Old Apr 18, 2005 | 07:40 AM
Jorsher's Avatar
Default Re: (Ninety5Ex)
You can get extraction screws, you just drill a hole in the sensor then drill the extraction screw backwards and it takes it out.
jorge89
Jul 27, 2013 06:44 PM
dorkjoey
May 8, 2008 03:07 PM
Ess0n23
Aug 10, 2007 10:01 PM
Fighterinsnatch
Apr 29, 2007 11:20 AM
Hybrid Invasion
Apr 10, 2003 05:18 PM
