problem with suspension set up
Old Apr 18, 2005 | 04:24 AM
markwitdada9
Guest
Posts: n/a
Default problem with suspension set up
so i put my tokico illuminas on yesterday..i love the ride but i am pissed as hell at how low the front can go.. right now the car is at its lowest setting all around.. the back is tuckin hard but the front is like its just sittin on the tire.. so i was wondering if anyone had this same problem or is there a way i can get another inch or so out of my ride height in the front only tho. and i dont really wanna get new coil overs cuz the set up is stiff as hell.. skunk2's with illuminas.. no bounce at all.. so heare are some pics of what i am talking about
BEFORE:
AFTER:
Old Apr 18, 2005 | 05:51 AM
markwitdada9
Guest
Posts: n/a
Default Re: problem with suspension set up (markwitdada9)
anyone?
Old Apr 18, 2005 | 05:57 AM
elpiar's Avatar
Is your fender to ground height the same front and rear? That's what you should measure, not how much the tires is tucked in.
Old Apr 18, 2005 | 06:13 AM
DANG YO's Avatar
Default Re: problem with suspension set up (elpiar)
in the front u can take out 1 of the adjustment screw things or flip ur sleve upside down and remove one also... worked for me
Old Apr 18, 2005 | 06:16 AM
94integragsr's Avatar
Banned
Default Re: problem with suspension set up (dc2kid)
what kind of springs are u using they might be in wrong fronts are different than the rear
Old Apr 18, 2005 | 06:27 AM
markwitdada9
Guest
Posts: n/a
Default Re: problem with suspension set up (94integragsr)
im using skunk 2's... also there are like to rubber things that are on the struts.. i was wondering if i were to cut those off maybe it would go lower ..
ribal_gh
Suspension & Brakes
10
Sep 10, 2012 04:36 PM
koumatae
Suspension & Brakes
Jun 27, 2012 06:56 PM
ghostrida
Nov 18, 2006 08:38 PM
Senbonzakura
Suspension & Brakes
Nov 6, 2006 05:50 PM
urquidezj
Apr 5, 2004 11:09 AM
