clutch pedal feels very odd
well i drove around a bit today...did some errands with the girlfriend etc...normal sunday
i am feeling a kind of 'grinding' or 'scartching' when i engage and disengage the clutch...predominantly when moving from a deap stop while in first.
car is not beat on....clutch/flywheel/pressure plate replaced all OEM about 5000 miles ago....tranny fluid just drained and replaced at acura....any idears? it was very hot out today...hottest its been in months out here in nj...could the viscosity in the clutch fluid have gotten a little funky?
ive searched but didnt find anything as specific as this.
it looks like best bet is to bleed the clutch and go from there?
someone lend a helping hand..
make sure the fluids full, bleed the clutch, check the fittings that go into the slave cylinder and master cylinder to see if they're leaking or messed up, and/or see if slave cylinder is working (my car grinded when my went, cause the clutch can't fully disengage).
note im not hearing anything...just feeling through the pedal....its very odd and im totally stumped
anyone have any ideas as to what could potentially be the problem?
clutch will be bled and filled tomorrow
