early rev limiter on b16a2 problem
Old Apr 17, 2005 | 06:34 PM
killaj12's Avatar
Default early rev limiter on b16a2 problem
hey i have a 00 si
i searched and found some possible solutions but i have a question regarding oil ..
when i drove home today, i couldnt take my car past around 6000 rpm, if i tried the rev limiter would kick in. Vtec does kick in, but it doesnt let me rev past 6000 rpm ..
i think im over due for an oil change, could this be the problem ?
also, when i searched, someone mentioned that a dented oil pan could cause this problem .. my car is pretty slammed, and i know my oil pan is gettin roughed up pretty bad .. is this the reason ?
anyway, any help is appreciated . thanks
Old Apr 17, 2005 | 06:37 PM
civictildeath's Avatar
Default Re: early rev limiter on b16a2 problem (killaj12)
ok if your water wasnt at 160 (maybe 190) degrees or higher, there is an unkonwn thing that is a cold rev limiter. it does the same as a rev limiter only sooner when water is cool to protect the engine. the only way to get rid of it is to reset the ecu.
Old Apr 17, 2005 | 06:59 PM
killaj12's Avatar
word .. maybe ?
neway, i just took my car out again and it seems fine so hopefully it was just a fluke kind of thing ...
thanks for the info tho
Damon Reeves
Jan 31, 2008 07:37 PM
H22Honda98
Jan 3, 2008 05:41 PM
timsch75
Jan 22, 2006 10:40 AM
danacixem
Aug 10, 2004 01:13 PM
vtecplaya18
Jul 15, 2004 08:59 AM
