My valve cover thread... PAINTED!!
at Discount/Advance Auto Parts they sell this Bedliner Spray (long spray can). it comes out textured...
the wrinkles look real thick... but not so bad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opiumdaze »</TD></TR><TR><TD CLASS="quote">you sprayed thick and heavy coats thats why it came out with huge wrinkles</TD></TR></TABLE>
The heavy wrinkle is actually what I wanted. I think it looks good!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2point0 »</TD></TR><TR><TD CLASS="quote">how did you masked out the letterings?</TD></TR></TABLE>
I didn't. I scraped the paint off in the morning with a butter knife, then used some sandpaper, 180 grit to take the paint off, then used 220 grit to smooth the surface out. After I used the polishing bit from the dremel set, but I didn't like that so I went over the letters again with the 220 grit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CIVIC dude »</TD></TR><TR><TD CLASS="quote">where did u manage to find the VHT crinkle paint in ontario? that **** is rare!</TD></TR></TABLE>
There's a stereo shop in downtown Kitchener here that sells it. It was $14, they have it in red and yellow too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eeeKs »</TD></TR><TR><TD CLASS="quote">nice...
get a heat shield</TD></TR></TABLE>
Have a heat shield, took it off to save time. I'm test fitting the turbo on Tuesday, I want to get it done as quick as possible.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch It »</TD></TR><TR><TD CLASS="quote">*its clean under there !
Thanks! I cleaned it all this weekend. There are still a couple of rusty bolts that I have to take care of, but it looks way better than before.
PS don't ever buy foamy engine cleaner unless you get two cans.
</TD></TR></TABLE>Thanks! I cleaned it all this weekend. There are still a couple of rusty bolts that I have to take care of, but it looks way better than before.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OEM_ASSASSIN »</TD></TR><TR><TD CLASS="quote">looks like you painted the cruise control...</TD></TR></TABLE>
Correct... it was rusty. Besides the valve cover, there are three more things that aren't so easy to spot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BS 22 »</TD></TR><TR><TD CLASS="quote">Looks good...i'll get around to doing that one day.</TD></TR></TABLE>
haha same here
haha same here
