drive shaft seal name
ok so i put in a ACT clutch and everythign goes well. until i take a road trip to rochester ny(where i am now) i get here and its fine, then driving around 5th gear starts to pop out. ok low fluid (lots of searching on HT to find out what it is.) ok low fluid, top off and good to go right? nope, found out that the seal that holds the CV shaft from the left side was ripped. i saw it before when putting the tranny back together but didn't think it was that big a deal cuz it was a teenie tiny tear. but now its seeping (spell?) so whats its called? and where can i get it soon and for how much?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bk11383 »</TD></TR><TR><TD CLASS="quote">got it! thanks, found out it was called a drive shaft input seal</TD></TR></TABLE>
Whoever told you that name is wrong. Its NOT a drive shaft!
A drive shaft is before the differential and the seal you have is after the differential.
Honda does not call it that either so you must have gotten it form your local parts store. Im not saying the parts company didn’t label it that but either way there wrong.
blackeg
Nov 19, 2004 03:22 PM
