need help with front windshield.. what products do you use/recomend to clean hard water stains??
like the title states, what do you use to clean off the hardwater stains after rain storms, or washing your car out in the sun?
cuz i bought a brand new windshield about a month or so ago, and its aready showing those damn spots.. and i wanan take them off. also the lines on where the windshield wipers run on the window, and where they dont? you know what i mean?
anywyas what could i use to clean the window so it looks like its brand new again..
i've tried simple glass cleaner, doesnt work.. i havent tried anything besides that tho.
Not too sure how to remove it from your windshield but I assume its all over your paint too. For the paint use 3M Clear coat safe rubbing compound. I have used that on two all black cars that were covered in water spots so much that you couldn't even see your reflection in the paint right after a car wash. When I was done with the rubbing compound the paint looked brand new. Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f2rider »</TD></TR><TR><TD CLASS="quote">Not too sure how to remove it from your windshield but I assume its all over your paint too. For the paint use 3M Clear coat safe rubbing compound. I have used that on two all black cars that were covered in water spots so much that you couldn't even see your reflection in the paint right after a car wash. When I was done with the rubbing compound the paint looked brand new. Good luck.</TD></TR></TABLE>
Depending on the severity of the water spots, you might not want/need to use a product as aggressive as rubbing compound. A fine polish might work - you always want to go from the least aggressive product and work your way up.
this is a simple one.....
use toothpaste.....
and watch it go away like magic.....
use toothpaste.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.beeks »</TD></TR><TR><TD CLASS="quote">this is a simple one.....
use toothpaste.....
and watch it go away like magic.....</TD></TR></TABLE>
you're kidding me right? u serioius? this works?!?!?!
use toothpaste.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebpda9 »</TD></TR><TR><TD CLASS="quote">0000 steel wool. i use it to clean windows all the time on my cars. no scratches whatsoever</TD></TR></TABLE>
....Uhhhh... I dont think its a good idear to use steel wool on glass.
I use windex + newspaper and it removes hard-water deposits like a charm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.beeks »</TD></TR><TR><TD CLASS="quote">use toothpaste.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CLMTAutoXR888 »</TD></TR><TR><TD CLASS="quote">I use windex + newspaper and it removes hard-water deposits like a charm.
I'd go with either one of these for your glass
</TD></TR></TABLE>I'd go with either one of these for your glass
clay it, then use zaino glass polish worked in with a porter cable polisher if you have one. this is tried and true method, my girlfriend parked her car next to sprinklers and it baked in the sun all day. to top it off, i didn't work on it for at least a month after that
use toothpaste.....
if you smear some toothpaste over the mirror in your bathroom and clean it back off....when you take a shower, it won't fog up any more!!!
ahhh....the wonders of toothpaste...what will they think of next?!?
use toothpaste.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NeoGSR »</TD></TR><TR><TD CLASS="quote">
ahhh....the wonders of toothpaste...what will they think of next?!?</TD></TR></TABLE>
haha...yeah man, have you tried it on silver, rims, headlights.........it's the duct tape of cleaning products
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cliffjumper2 »</TD></TR><TR><TD CLASS="quote">
will it help keep the polished lip cleaner longer?
</TD></TR></TABLE>will it help keep the polished lip cleaner longer?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ..::91TEG-G2::.. »</TD></TR><TR><TD CLASS="quote">
will it help keep the polished lip cleaner longer?</TD></TR></TABLE>
I've never tried it on a polished lip of a wheel..........I'd suggest you try a small spot more towards the inside of the lip, and see how it looks in several days.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ..::91TEG-G2::.. »</TD></TR><TR><TD CLASS="quote">will it help keep the polished lip cleaner longer?</TD></TR></TABLE>
wax your wheels, they will stay cleaner and wash easier.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hadboosttroy »</TD></TR><TR><TD CLASS="quote">
wax your wheels, they will stay cleaner and wash easier.</TD></TR></TABLE>
guess I can't argue with that.
An other tricks is Coka-cola classic for windshield, chrome everithing bling-bling! With newspaper it does a great job!
I also heard that toothpaste was good for theets
I was skeptical about it
so I tried it cause I had a lot of little scratches on windshield so
this guy tells me to try it.
so I did and it worked like a charm
especially for those headlights that are made out plastik..
and turn yellowish...
it works wonders on them after a couple of times that I did it it looked like new
and then I waxed it...
i think toothpaste works kinda like a wax, it's gotta little bit of an abrasiveness to it, and fills up the "holes" kinda like a wax would.
ok, since we're on the subject of headlights.. the side markers up on the headlight set (for a DA) where the white bulb goes into (not the side marker amber light goes) is kinda blackish.. its not on the outside i dont think.. i think its on the inside, how would i go about cleaning this? i'll take a pic of it if you guys would like me too
you'd have to heat up the light in the oven, pull it apart, and start cleaning from there. i would use a product called "plexus", it is awesome **** for plastic.
well i just did the brakes and was gettin ready to wash the car.. got done with that, and went to wash the windows seperate.. couldnt find any ****** newspaper!!! i was pissed.. gota go buy the sunday tomorrow and wash the windows. lol
