tach, gas, temp gauge stopped workin..HELP PLEASE!
Old Apr 17, 2005 | 04:33 PM
mawkiemarc's Avatar
Default tach, gas, temp gauge stopped workin..HELP PLEASE!
89 si hatch with 200,000 miles. i stopped at a friends house for a lil bit and when i left i first noticed i had no gas, than no rpm's then no temp but i could tell how fast i was goin bc the speedo still worked. is there ne one who has experienced this or could point me in the right direction on ho to fix this.....thanks!
Old Apr 17, 2005 | 05:09 PM
dr_latino999's Avatar
Default Re: tach, gas, temp gauge stopped workin..HELP PLEASE! (mawkiemarc)
Fuse for the gauge cluster went kaput.
Old Apr 17, 2005 | 06:27 PM
bagpipe goatee's Avatar
listen to the doctor, also if you've had it apart recently, the plugs are sometimes finicky to go back in right, seem to work, but then could fall out down the road. but if you had the cluster out, you'd have probably checked that first before posting here.
Old Apr 17, 2005 | 07:03 PM
mawkiemarc's Avatar
Default Re: (bagpipe goatee)
thanks dr_latino999, i forgot to check that and no bagpipe goatee i havent taken the cluster apart or got a new one put i see what your sayin about the plugs not bein in right but nah i dont think they are out, i mean is it likely that they could just come out with me driving, like out of no where?
Old Apr 17, 2005 | 07:17 PM
Default Re: (mawkiemarc)
You never know, you're cluster bearings might have failed causing the dislocation of the plugs...either that or cluster gnomes.
Old Apr 17, 2005 | 07:24 PM
Slow ass EF's Avatar
Default Re: (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">You never know, you're cluster bearings might have failed causing the dislocation of the plugs...either that or cluster gnomes.</TD></TR></TABLE>
lmfao
Old Apr 17, 2005 | 08:03 PM
EvolDead's Avatar
i recently put blue faced gauges in and my fuel and temp gauges no longer work.I checked the plugs and still nothing.
Old Apr 17, 2005 | 08:08 PM
Default Re: (EvolDead)
Odds are you shorted out the traces or something else along the lines. BTW, my Red lit stock faced gauges own all.
Old Apr 18, 2005 | 03:53 PM
mawkiemarc's Avatar
are there directions in the haynes manuel on how to take apart the cluster? i couldnt find it in my manuel but is there any way someone could tell me how to take it apart for me to look at the plugs? thanks......
Old Apr 18, 2005 | 06:46 PM
mawkiemarc's Avatar
bump.....
Old Apr 18, 2005 | 07:30 PM
TIRENECK's Avatar
I had the same problem before but out of nowhere it got fixed. I tried to troubleshoot it with no luck but something always told me it had something to do with my distributor. I wish I really knew what happen.
Old Apr 18, 2005 | 07:38 PM
about taking apart the cluster, haynes i'm pretty sure doesn't cover it. haynes sucks, anyway. its not hard to take apart, just remember don't pull off the needles because the gauges can get messed up. they don't always, but often they do.
Old Apr 18, 2005 | 09:36 PM
2kTeg's Avatar
check your hazard fuse under the hood and the turn signal fuse under the dash, if none of your blinkers work the cluster will sometimes act funny
Old Apr 19, 2005 | 05:19 AM
mawkiemarc's Avatar
alright thanks, bump for some more into please......!
Old Apr 19, 2005 | 06:36 AM
https://honda-tech.com/zerothread?id=1216528
Old Apr 19, 2005 | 09:24 AM
mawkiemarc's Avatar
alright thanks....
MTarry
11
Jan 15, 2013 06:46 PM
tekniq
Jan 14, 2009 08:38 PM
bigboi_626
Jun 6, 2007 10:27 PM
dets93teg
Jan 16, 2007 04:32 AM
