What plug is this for?
Old Apr 17, 2005 | 04:30 PM
wtsexton's Avatar
Default What plug is this for?
I picked up an harness for my 88 Si because I screwed up the last.
This harness should be from a 88-89 Si.
The engine its going on is a b16a and I can't figure out what this plug goes to. To make matters worse its been depinned so I can't just go by where ever it plugs.
Old Apr 17, 2005 | 04:53 PM
sit220's Avatar
Default Re: What plug is this for? (wtsexton)
i tho they were for the reverse lights but after seen the oil filter next to it
not sure
Old Apr 17, 2005 | 04:56 PM
Hcivic88's Avatar
Default Re: What plug is this for? (sit220)
I believe thats for the oil pressure switch. if you look on the block, there will be two plugs just on top of the oil filter, one that is just a one pin(where that big round rubber plug in the pic goes) and one thats the same thing, but with two pins(which is where those two pins your asking about go)
If you cant figure out what i mean by that just let me go and ill go snap a quick pic for ya(luckily enough i have my zc swap sitting in my garage)
Old Apr 17, 2005 | 05:02 PM
No-Gi's Avatar
Default Re: What plug is this for? (Hcivic88)
The oil pressure is only one Pin. This one is for the coolant sensor.
Old Apr 17, 2005 | 05:07 PM
wtsexton's Avatar
Default Re: What plug is this for? (3_South)
Old Apr 17, 2005 | 05:13 PM
RCautoworks's Avatar
Radiator fan switch.
Old Apr 17, 2005 | 05:24 PM
wtsexton's Avatar
Default Re: What plug is this for? (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Radiator fan switch. </TD></TR></TABLE>
If the fan switch is the two pronge sensor below the oil sensor then that is already plugged in.
Old Apr 17, 2005 | 05:34 PM
civiccrx21's Avatar
in that area you have , reverse lights, ECT sensor , im thinking reverse lights
Old Apr 17, 2005 | 05:38 PM
wtsexton's Avatar
Default Re: (civiccrx21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccrx21 &raquo;</TD></TR><TR><TD CLASS="quote">in that area you have , reverse lights, ECT sensor , im thinking reverse lights</TD></TR></TABLE>
FYI, thats the rear of the block not the front. The ecu, reverse lights, o2 sensor, temp gauge are hooked up.
Old Apr 17, 2005 | 07:46 PM
wtsexton's Avatar
Looks like this maybe a hf harness.
Old Apr 17, 2005 | 07:54 PM
jlicrx's Avatar
Default Re: (wtsexton)
if those wires are one blue and one black with yellow stripe, they are for the fast idle control valve on the 89-91 Si - your harness must be for 89 because 88 didn't have fast idle control valve - 89 harness will not plug into chassis harness on the driver's side - 89 has round 7-wire connector - 88 has square 5-wire connector - the other 2 wires are for the FICV
Old Apr 17, 2005 | 08:00 PM
SiR Inspired ED7's Avatar
seems like you pulled it out off some kind of plug. check your plugs and see what dont work. if something like a sensor dont work, that might be your problem
Old Apr 17, 2005 | 08:25 PM
wtsexton's Avatar
Default Re: (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">if those wires are one blue and one black with yellow stripe, they are for the fast idle control valve on the 89-91 Si - your harness must be for 89 because 88 didn't have fast idle control valve - 89 harness will not plug into chassis harness on the driver's side - 89 has round 7-wire connector - 88 has square 5-wire connector - the other 2 wires are for the FICV</TD></TR></TABLE>
Yea, I just noticed that. Guess I'm gonna have to order a new harness from honda.
Old Apr 17, 2005 | 08:31 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wtsexton &raquo;</TD></TR><TR><TD CLASS="quote">
Yea, I just noticed that. Guess I'm gonna have to order a new harness from honda.</TD></TR></TABLE>
i screwed up - it is actually round 8 wire and square 6 wire
Old Apr 17, 2005 | 08:52 PM
wtsexton's Avatar
Yea, it is still different.
Old Apr 17, 2005 | 08:54 PM
cbrodac0424's Avatar
those are foe your reverse lights.
Old Apr 17, 2005 | 09:45 PM
DieMaster's Avatar
Needs to be About 20% Cooler
can u say $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ and even more $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
i would just short them together. if u blow a fuse than find whats on that fuse that u dont have. or if ur revirse lights work , enough said
Old Apr 17, 2005 | 10:00 PM
bob06's Avatar
http://effinmotorworks.com/Effin_MPFI_swap.htm use the colored pinout at the bottom to find out what the wires are for. From what i saw it looks like a blue/yellow and a black yellow. I thought it was EACV so i went out and looked at my eacv wires and they are blue/yellow and black/yellow. The blue/yellow is listed as IACV on the color-coded pin out also.
Old Apr 17, 2005 | 10:04 PM
wtsexton's Avatar
For those who keep saying its the reverse lights, You are WRONG. I repeat they are not for the reverse lights. What would the reverse light wiring be doing under the intake manifold? Its for a sensor that my year didn't have thats why its extra. Its just missing the plastic plug.
Old Apr 17, 2005 | 10:11 PM
wtsexton's Avatar
Default Re: (DieMaster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DieMaster &raquo;</TD></TR><TR><TD CLASS="quote">can u say $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ and even more $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
i would just short them together. if u blow a fuse than find whats on that fuse that u dont have. or if ur revirse lights work , enough said </TD></TR></TABLE>
$196.
Old Apr 17, 2005 | 10:39 PM
FTPPRELUDE's Avatar
looks to me like the reverse light wires
Old Apr 18, 2005 | 01:34 AM
limpy's Avatar
Default Re: (FTPPRELUDE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FTPPRELUDE &raquo;</TD></TR><TR><TD CLASS="quote">looks to me like the reverse light wires</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wtsexton &raquo;</TD></TR><TR><TD CLASS="quote">For those who keep saying its the reverse lights, You are WRONG. I repeat they are not for the reverse lights. What would the reverse light wiring be doing under the intake manifold? Its for a sensor that my year didn't have thats why its extra. Its just missing the plastic plug.</TD></TR></TABLE>
Old Apr 18, 2005 | 03:00 AM
mdarnell's Avatar
my buddies 88 hf harness had those...i couldnt find where they plugged into on an SI block...then again i didnt look too hard. im away from the car right now, but im pretty sure it runs fine without them plugged up
avenger63
Apr 6, 2016 10:25 PM
Kprettyman
Oct 10, 2013 08:38 AM
thabao
Jan 31, 2008 07:03 AM
homesauce
Jun 1, 2006 10:02 PM
GroundZer0 336
Mar 29, 2005 08:12 PM
