how can i hook up vtec with out the wiring harness?
hey i got a mini-me swap B7 block with a Y8 head...if i dont have the wiring harness for the y8 is their another way around this to wire up vtec?
I'm going to assume that you have a vtec ecu. all you have to do is run the vtec oil pressure and the vtec soleniod wire straight to the ecu. Get a pinout of you vtec ecu so you can see where the pins go
