WTH, heater has 1 speed
Old Apr 17, 2005 | 04:15 PM
wu tang's Avatar
Default WTH, heater has 1 speed
ok..so my heater has 1 speed. and that is high. does anyone have a diagram on the EF8 heater?? please let me know
Old Apr 17, 2005 | 04:19 PM
Super Chicken's Avatar
Default Re: WTH, heater has 1 speed (wu tang)
Part number 5 the blower resistor. It reduces the voltage to the fan motor for 1,2 &3 and the little resistors burn out after a while. Seems like when one goes the others follow soon after
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Probably the resistor right behind the glovebox...
the thing in the middle with wires going to it...
Old Apr 17, 2005 | 04:21 PM
wu tang's Avatar
Default Re: WTH, heater has 1 speed (88DXCRX)
well i also think it has something to do with my wiring...so thats why i was wondering also if anyone had a diagram of what each wire means coming out of the climate control. thanks guy for your help allready
Old Apr 18, 2005 | 12:43 PM
wu tang's Avatar
got the heater to work! now i just need to know why wont any of my vents open up??
Old Apr 18, 2005 | 02:16 PM
ZhaGg's Avatar
check for voltage on the little green plug that goes to the back of your climate control unit. There should be voltage on the yel/blk wire and blk wire. they are the power supply for the whole climate control system (at least the actuators...) If you are able to change from recirc to fresh, but not the vents, then you need to check the connector to the vent actuator. If they both don't work, make sure the green plug in fully inserted...
This may also help... http://tech.hybridgarage.com/t...l.pdf
Old Apr 18, 2005 | 02:28 PM
AllMotoRex's Avatar
how did you get it to work!?
Old Apr 18, 2005 | 04:20 PM
wu tang's Avatar
Default Re: WTH, heater has 1 speed (AllMotoRex)
well the motor blows on all speeds, the lights turn on..but the vents wont open..so its those green plugs in teh back?
SpOoLiNg CiViC
Dec 8, 2009 03:35 PM
CivicInspired
Honda Civic (2001 - 2005)
Aug 17, 2007 08:44 PM
Playboy07
Jan 28, 2006 12:18 PM
