What hose is this called exactly when Autozone people look it up?
Old Apr 17, 2005 | 04:00 PM
cpforyou's Avatar
Default What hose is this called exactly when Autozone people look it up?
I need the hose that connects to the water pipe, the opening on the left that comes out towards the picture. Mine is leaking, so I need to replace it, but the people at Autozone don't know what hose I'm talking about.
In this picture, it's the hose that is above the oil filter attached to the water pipe.
Modified by cpforyou at 5:22 PM 4/17/2005
Old Apr 17, 2005 | 04:01 PM
Greyout's Avatar
Default Re: What hose is this called exactly when Autozone people look it up? (cpforyou)
n/m... new pic helps...
Modified by Greyout at 5:27 PM 4/17/2005
Old Apr 17, 2005 | 04:06 PM
cpforyou's Avatar
Default Re: What hose is this called exactly when Autozone people look it up? (Greyout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greyout &raquo;</TD></TR><TR><TD CLASS="quote">doesn't that go to the throttle body?
they probably don't stock it, you'd either have to order it from honda, or jsut get a length of 3/8" hose and cut it yourself.
edit: nevermind, I think I was looking at it backwards... its a heater hose, correct? it goes to the heater core, through the firewall?</TD></TR></TABLE>
It runs directly from the water pipe to the head (right underneath the distributor). I don't have a heater. So those w/ a heater, it goes to the heater, and then back to the head?
Modified by cpforyou at 5:24 PM 4/17/2005
Old Apr 17, 2005 | 04:24 PM
Greyout's Avatar
I'm going back to my original answer: heater hose
edit: yes, if you don't have a heater, then it would go to the spot that the "B-17-30" attaches to the head.
can you even get a prelude w/o a heater? if not, then it'd be a custom length hose, or you'd have to use a brass fitting to put the two together.
Old Apr 17, 2005 | 04:29 PM
cpforyou's Avatar
can you even get a prelude w/o a heater? if not, then it'd be a custom length hose, or you'd have to use a brass fitting to put the two together.</TD></TR></TABLE>
Thank you very much, it's a great help. I just did not know what it was called officially.
No, you cannot buy a Prelude w/o the heater. The heater was taken out to save weight, and the two hoses were joined together with a fitting.
HndaOwner
Mar 8, 2016 04:14 PM
honda_racing101
Nov 2, 2007 12:47 PM
joebark
Sep 27, 2004 08:25 PM
Prod
Sep 16, 2004 07:29 AM
SmasonGSR
Jun 25, 2004 08:56 PM
