600whp which SLICKS??
engine: GSR
produces 600whp...
using a b16 tranny...
which size slicks is best???
I was thinking 26x9x15
which suspension???
I was thinking OMNI racing suspension
opinions and/or experiences would be appreciated.....
produces 600whp...
which suspension???
24x8.5 are a good choice. you have to look at what kind of clearence you have in the wheel well area, and if you are going to be rubbing the outside of the fender well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jason@Rage »</TD></TR><TR><TD CLASS="quote">NHRA = 25x8.7x13
NDRA - IDRC - CMI = 26's if you can fit them
Not matter the tire run the M&H get tire great service.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgh99si »</TD></TR><TR><TD CLASS="quote">omnipower drag suspension
mh slicks
cannot go wrong</TD></TR></TABLE>
you might be able to install them wrong...
mh slicks
ook so with only 600whp the 26" slicks aren't recommended then??? It would be best to go back to the 25x8.7x13 m/hs. We used to run those when we made 430whp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtecpower »</TD></TR><TR><TD CLASS="quote">ook so with only 600whp the 26" slicks aren't recommended then??? It would be best to go back to the 25x8.7x13 m/hs. We used to run those when we made 430whp.
What I've seen with most people running 26s...Is a broken driveline.
2wheelhunter
Jul 22, 2008 01:06 PM
Turbo O
Oct 16, 2006 08:38 PM
tweekerz
Mar 24, 2005 02:08 PM
