What to check for when buying a used bike?
Old Apr 17, 2005 | 01:00 PM
user 996328629's Avatar
Default What to check for when buying a used bike?
I had searched and came up with nothing that was to informative.
Now i have some motorcycle knowledge, but when people say check tires, check forks, ect. ect.... To someone who has limited knowledge, all they might do is look at the tread, not knowing what to look for when actually looking at the tread.
I plan on buying a used bike shortly and i just want to know and for others future ref.. What to check for, and if its a procedure or know how, how to understand/perform the check...
-From what I was told, checking the outside of the tire, the larger the "flat" part is (chicken somthing) will tell you if the bike was leaned/driven hard..
Old Apr 17, 2005 | 02:29 PM
Phaze2 Mike's Avatar
Honestly...find a local shop and pay them to check it out. My bike has no chicken strips cause i lean the bike to the end of the tire, but i treat it nice and dont abuse it, i simply ride well.
Old Apr 17, 2005 | 03:00 PM
Default Re: (Phaze2 Mike)
Well for those of us who just want to know, without always needing a shop..
Any info is good to know before you buy, or while you own..
Old Apr 17, 2005 | 03:19 PM
Default Re: (Swags04)
Well, im sure this has been covered better elsehwere, but things id look for:
Push down on the shocks, see if they go down or get stuck too easily (well they should never get stuck). Check for leaking fluid from them. CHeck for rubber spit up on the hugger or undertailf or burnouts, check the chain for wear and slack, check rear wheel alignment, ask when maintinece is done, by who...receipts. Check the rear sprocket...worn teeth? Start the bike cold, watch it warm up, ride it for a bit or at leats run and rev it, does it miss, power spots and bogs? Smoke?
Old Apr 17, 2005 | 05:38 PM
Apocalypse's Avatar
Default Re: What to check for when buying a used bike? (Swags04)
First post of first thread....
http://www.clarity.net/adam/buying-bike.html
Old Apr 17, 2005 | 09:43 PM
Muffler Bearing's Avatar
Awesome thread, keep it going.
Starscream
Honda Motorcycles
Jul 8, 2007 01:10 AM
UNDER PRESSURE
Honda Motorcycles
May 30, 2007 10:42 AM
Racerage1
Honda Motorcycles
Jan 16, 2004 05:46 AM
mckenzie
Honda Motorcycles
Sep 10, 2003 07:08 PM
