Common symptoms of high idle (d16Z6/D16a6) mini me? You tell me..
Old Apr 17, 2005 | 12:48 PM
EJ2-Fluffy's Avatar
Default Common symptoms of high idle (d16Z6/D16a6) mini me? You tell me..
Hey just recently finished a Mini me swap using a D16z6 head/D16a6 block. No check engine lights.
My idle jumps upto 2500 rpm and stays there then goes down toe 1500. (which is normal for the idle to jump high as coolant temperature is low until it reaches normal temperature)
Options:
- TPS sensor
- Vacuum lines
- EACV (I have a vacuum line from the TB connected to it, on the other nipple a coolant line is connected to it...is this correct?)
What else can cause this? I ran FI cleaner and still no help.
Thanks in advance again,
Jon
Old Apr 17, 2005 | 12:55 PM
black88si's Avatar
Default Re: Common symptoms of high idle (d16Z6/D16a6) mini me? You tell me.. (CRX-Fluffy)
Sounds like you have air in the coolant system. Bleed it. The 2 nipples on the EACV are both coolant hoses.
Old Apr 17, 2005 | 01:14 PM
EJ2-Fluffy's Avatar
Default Re: Common symptoms of high idle (black88si)
Hmm thats probably why. I have one of the TB vacuum lines going to my EACV. Lol crap i wonder where that TB line goes too though =\
Old Apr 17, 2005 | 03:20 PM
black88si's Avatar
Default Re: Common symptoms of high idle (CRX-Fluffy)
give me a picture, If its a vac line for sure it probably goes to the charcoal canister. If its a coolant line there should be a fitting coming off of the Intake manifold for the hose.
Old Apr 17, 2005 | 05:45 PM
EJ2-Fluffy's Avatar
Hmm I have it correct. Its not the vacuum and coolant lines. What else could it be?
Old Apr 18, 2005 | 02:26 PM
EJ2-Fluffy's Avatar
Anyone?
Old Apr 18, 2005 | 03:19 PM
nsone's Avatar
I've got the same problem.
I'm a Noob to the community and Honda Hatchies.
Purchased the car a month ago. 91 hatchie si.
The car used to be a track car.
It's got the stock D16.
I have the same Idle problem as Fluffy's.
I'm trying to figure out whawt kind of Mods they did to this car, aside from the horrendous paint and body.
Old Apr 18, 2005 | 04:58 PM
1gEF-8's Avatar
which intake manifold are you using z6 or a6
Old Apr 18, 2005 | 06:30 PM
nsone's Avatar
Default Re: Common symptoms of high idle (1gEF-8)
hence the newb that i am,
how do i find out?
Old Apr 18, 2005 | 06:42 PM
EJ2-Fluffy's Avatar
Im using the 96-00 SI manifold (D16Y8). There isn't any vacuum leaks (i plugged up the TB and it shut the engine down) I'm guessing there must be air bubbles in my coolant. Anyone know how to get rid of them?
Thanks,
Jon
Old Apr 18, 2005 | 07:43 PM
Its me DUB's Avatar
i have the same high idle prob too. when you find out, i would be interested in knowing. i will let you know if i figure anything out fluf.
Old Apr 19, 2005 | 01:07 PM
EJ2-Fluffy's Avatar
Default Re: Common symptoms of high idle (doitdub)
Well i guess i can go substitute for another IACV. Well see if that works.
Old Apr 19, 2005 | 01:11 PM
92integra_gs's Avatar
yea tell me how it goes when you swap that EACV/IACV cuz i am having the same problems wid my Y8 IM w/ d15b2/z6 mini-me... btw do you have a dashpot vacuum line wid that Y8 IM ?
Old Apr 19, 2005 | 01:37 PM
black88si's Avatar
Behind and below the distributor is the thermostat housing. On that housing is the bleeder valve for the coolant system. Use a 10mm socket on a long extension and loosen the valve. Then fill your radiator using the hose (or some other pressurized water) until a solid stream of water comes out the valve. Once there are no air bubbles, tighten the valve back down and replace your radiator cap.
Old Apr 19, 2005 | 09:01 PM
EJ2-Fluffy's Avatar
Right on, will do this tomorrow. Thanks alot xD
Old Apr 19, 2005 | 10:44 PM
vetrocrx's Avatar
I recently put a type R intake manifold on my b16 swap in a 89 rex and have those same issues, wondering if its possibly idol air control.....
Old Apr 19, 2005 | 11:28 PM
dohdoh420's Avatar
Default Re: Common symptoms of high idle (vetrocrx)
I also have a similar problem.. I took my intake manifold off to clean it and do some mild porting, and it idles at way low like at 800-900 rpm.. so low the tach doesnt read it, then from 1000rpm to about 2300rpm it is very choppy unless I am flooring it, like I'm racing or else in a very high gear at like 10mph keeping it under 1000rpm.
Old Apr 20, 2005 | 03:57 AM
TURBODEEZ's Avatar
Hey, if u used the A6 coolant neck than the bleeder screw is on the neck coming right of the head. And its a 12mm. Also check your throttle cable i know i had a lot of problems with that when i did my A6/Y8 mini me. Never had the idle problems like you have though.
Old Apr 20, 2005 | 06:32 AM
oldSCHOOLhonda's Avatar
high idle makes me think vaccume leak of some sort
Old Apr 20, 2005 | 09:02 AM
EJ2-Fluffy's Avatar
Default Re: Common symptoms of high idle (oldSCHOOLhonda)
bump any people with some knowledge of why its idling like that? Im thinking of just replacing every friggin vacuum lines =\ I need to fix this before the Eibach Meet!
Old Apr 20, 2005 | 10:17 PM
EJ2-Fluffy's Avatar
Old Apr 20, 2005 | 10:48 PM
vetrocrx's Avatar
I think there might be a vacume leak some where around the seal on my hondata gasket on the type R intake manifold but not sure....
Old Apr 20, 2005 | 11:01 PM
pcv valve could come unpluged.. down below the intake mani and above the oil filter.
check it out
u change im gasket?
Old Apr 20, 2005 | 11:17 PM
SECURITY's Avatar
Default Re: (oldSCHOOLhonda)
Here's a good link on idle troubleshooting:
http://www.ef-honda.com/ben/Badidle.php
Everything in there I reccomend as well as resetting your ECU (should be in one of the earlier steps)
Old Apr 20, 2005 | 11:18 PM
Nerologic's Avatar
have u checked the FITV?
this goes for everyone, it sounds like that is the issue..
im kinda lazy search under me under recent i have a thread regarding this...
