removing instrument cluster
Old Apr 17, 2005 | 11:38 AM
dlc's Avatar
dlc
Default removing instrument cluster
I have a 97 Accord that the fuel gauge has stopped working. I have purchased another cluster and would like to swap them out. However, yesterday I tried to remove the cluster and had some difficulty. I removed the screws at the top, the 2 that are behind the pop-out plugs, and the ***** for the ac,heat,etc. I can get the left side loose but the side around the hvac controls will not come out. What else do I need to remove to get the cluster out? Or please point me to a page with this info. Thanks in advance.
Old Apr 17, 2005 | 04:08 PM
Rok's Avatar
Rok
Okay, I've done the same for my accord when i changed it out for indigo guages...... here's what ya gotta do.... make sure to have baggies and labels for the skrews you will need it..this will also take about an hour or more to do
1) remove all swithches, Ac, Dimmer, Cruise,etc...
to do that just get a flat head screwdriver and pull them out and remove the wiring harness
2) remove skrews that should be seen through the holes where the swithes used to be
3) to get the ac cluster are lossened up from the dash, just remove the whole center console, to do this.
6) open the center console compartment/armrest remove the cover and remove screws at bottom,
7)then open cup holder pull it out, and remove screws, and pull center console away
8)remove crews from shifter plastic cover
9) the "rest" should pop out the (whole radio/clock plactic etc)
..... take a look under the dash at the open space where the clock and swithces used to be
10) remove that skrew that you see that is under the dash
11) once everything on the dash is unbolted pull on the ac and guage cluster together in a straight forward position...makesure to unplug all harnesses.....
and that should be it, and to put it back together just follow instructions backward
Old Apr 18, 2005 | 11:40 AM
dlc's Avatar
dlc
Default Re: (Rok)
Guess I didn't see the screw where the clock and switches are. Thanks for the info.
Old Apr 18, 2005 | 01:59 PM
Rok's Avatar
Rok
Default Re: (dlc)
sure no problem, oh by the way good job with the supra truck although it isn't a honda it's still a kicka$$ truck...........
thisiskev
May 3, 2010 05:10 AM
u2civic1
Jan 12, 2010 04:27 PM
SC2.2CL
Mar 29, 2006 11:03 AM
bgod
Dec 17, 2002 12:12 PM
bgod
Dec 17, 2002 10:53 AM
