rolling fenders?
Old Apr 17, 2005 | 10:37 AM
Yoshiod9's Avatar
From: vacaville for holiday, sacto for school, ca, united states
Default rolling fenders?
hey guys, i already did a search on rolling fenders but i never found out how far i should be rolling them. i'm upgrading to a 205/45/16 from a 185/65/14 and i'm pretty sure i'll rub (car is about a 2 inch drop...). should i be rolling them from 10-2 (if looking at an analog clock)? that's about what i would think would be decent. any thoughts? thanks in advance.
Old Apr 17, 2005 | 11:03 AM
stormy's Avatar
Default Re: rolling fenders? (Yoshiod9)
don't do it yourself, call around to a body shop and find one that has the right machine for it.
It may cost 100+ bux but the final result is worth it
Old Apr 17, 2005 | 11:11 AM
rodrez.'s Avatar
Most people use a bat to roll them, but you can really mess up the fender quite a bit if you're not careful. Also it can crack the paint, and it will spread.
A friend of mine in Vista has an actual fender rolling device at his shop, that bolts to your hub, and uses a wheel (sort of like a roller skate wheel) to flex the fender by rolling behind it and increasing pressure, but it's an expensive part, and I don't know if you can rent them anywhere.
Old Apr 17, 2005 | 04:38 PM
mR. Vash's Avatar
Default Re: rolling fenders? (rodrez.)
I'm trying to roll my fenders as well...paint chipped too..I'm just gonna take a hammer to it
Old Apr 17, 2005 | 04:42 PM
stormy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodrez. &raquo;</TD></TR><TR><TD CLASS="quote">Most people use a bat to roll them, but you can really mess up the fender quite a bit if you're not careful. Also it can crack the paint, and it will spread.
A friend of mine in Vista has an actual fender rolling device at his shop, that bolts to your hub, and uses a wheel (sort of like a roller skate wheel) to flex the fender by rolling behind it and increasing pressure, but it's an expensive part, and I don't know if you can rent them anywhere. </TD></TR></TABLE>
There only like 200 bux. The trick is to use a heat gun to allow the paint to flex without cracking
by far the best link
http://www.robsaudiworld.com/fender.htm
Old Apr 17, 2005 | 04:43 PM
reza
Default Re: rolling fenders? (GsRdHaTcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsRdHaTcH &raquo;</TD></TR><TR><TD CLASS="quote">I'm trying to roll my fenders as well...paint chipped too..I'm just gonna take a hammer to it </TD></TR></TABLE>
try starting more inward , it's less likely the paint will crack.
jdmblingn's Avatar
i know a few people that have done it sucessfully w/ a bat and a heat gun. if you dont mind the risk just be careful and take your time
Old Apr 17, 2005 | 05:51 PM
TRD MA70's Avatar
Default Re: rolling fenders? (stormy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stormy &raquo;</TD></TR><TR><TD CLASS="quote">don't do it yourself, call around to a body shop and find one that has the right machine for it.
It may cost 100+ bux but the final result is worth it</TD></TR></TABLE>
unless money isn't a factor, because i know we're all ballin
Old Apr 17, 2005 | 05:56 PM
stormy's Avatar
Default Re: rolling fenders? (TRD MA70)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TRD MA70 &raquo;</TD></TR><TR><TD CLASS="quote">
unless money isn't a factor, because i know we're all ballin </TD></TR></TABLE>
were talking about a car here right ?
if it's not worth 100 bux to have it done without doing ireversable damage to it if you mess up than maybe you should'nt ever get within 50 feet of my car
Old Apr 17, 2005 | 06:16 PM
Yoshiod9's Avatar
yeah, so i decided to give it a go with a bat. that worked fairly well for a bit but didn't give me the room i needed. so, i hammered it. the paint cracked and chipped away on the lip of the fenderwall but other than that...things went well. i just sanded down the chipped portions and primered them with no rust primer.
also, what do you do for the front fenders of a 99 civic? there really wasn't too much to roll...so i left them be for now. i figure that if the wheels/tires rub(getting them tomorrow) i'll just make sure to raise the car up a bit.
Old Apr 17, 2005 | 06:31 PM
iHATEspeedbumps.'s Avatar
i tried yesterday with a bat alone, didnt do a damn thing. do i need to heat it up? i dont care about paint chip, car is going to the booth next saturday. input?
Old Apr 17, 2005 | 06:36 PM
Yoshiod9's Avatar
lol. you must've been doing it wrong then. put the bat in the fenderwell and put downward force whilst rolling the bat back and forth over the metal. using a bat, it'll take hella long. if you're going to paint next week, take a 4lbs sledge and hammer the ish outta the fenders. that's basically what i did. just do a pre-measurement to figure out how smashed you want them. i did it so i had about 1/4 inch or so left as a fender. lol.
Old Apr 17, 2005 | 06:54 PM
Default Re: (Yoshiod9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yoshiod9 &raquo;</TD></TR><TR><TD CLASS="quote">lol. you must've been doing it wrong then. put the bat in the fenderwell and put downward force whilst rolling the bat back and forth over the metal. using a bat, it'll take hella long. if you're going to paint next week, take a 4lbs sledge and hammer the ish outta the fenders. that's basically what i did. just do a pre-measurement to figure out how smashed you want them. i did it so i had about 1/4 inch or so left as a fender. lol. </TD></TR></TABLE>
thats what i was thinking, well ima shave it now. easier for me to do. good luck with yours.
Old Apr 17, 2005 | 10:05 PM
buyer's Avatar
thats the spirit!
Old Apr 18, 2005 | 08:10 PM
TRD MA70's Avatar
if it's not worth 100 bux to have it done without doing ireversable damage to it if you mess up than maybe you should'nt ever get within 50 feet of my car</TD></TR></TABLE>
no, I meant I'd go to a professional unless you can afford to mess up your fender and paint using the bat method and afford to fix it at a shop right away.
Sean @ ESG
Feb 13, 2006 11:34 PM
cilvia
Nov 16, 2005 06:47 AM
Finger Lickin' good
Oct 2, 2004 06:53 PM
Integra21
Feb 23, 2003 04:51 PM
Hawk2max
Jan 16, 2003 01:38 PM
