brake / blinker / stalling issue...HELP!
Old Apr 17, 2005 | 07:24 AM
Dave421's Avatar
Default brake / blinker / stalling issue...HELP!
Ok, I'm thoroughly confused by this one so I'm hoping someone here has run into it before. Yesterday, I was hired to correct an engine swap. It was a 1st gen. b16 into a 90 std. hatch. I've never seen anything that was done as badly as the wiring on this swap. Actually took me over 8 hours to correct everything done wrong (spade connectors, butt connectors that weren't attached, horrible solders, etc.). Anyway, the car had an issue with the lights causing the motor to stall and the brake pedal turning the front blinkers on. I was hoping it was just something they screwed up installing the motor but I didn't find anything.
Basically, if you hit the brakes, the front blinkers illuminate and the motor bogs & dies. If you put it in reverse, the motor bogs and dies. Same thing with the headlights. I also noticed that once the car is started, the fuel gauge drops to empty (I'm not sure as to any other gauges as it wasn't run long enough to get the temp. up and there's no tach in the stock cluster).
I checked all of the wiring I could find and saw no problems. I checked the light switch and it did the same when it was disconnected (I've had a similar problem where this was the cause). Checked the blinker relay in the fuse box and did the same when it was connected. Main relay = same issue. Other relay near main relay & hood release (made by Denso) and it still did it. All of the visible wiring looks fine. I couldn't find anything related in the service manual for trouble shooting. Looking at the wiring diagrams, I see that they're all on the same circuit but I still can't figure it out. Does anyone have any ideas??? I'm thoroughly confused by this one.
Old Apr 18, 2005 | 06:25 AM
Dave421's Avatar
bump... anyone have any ideas??
Old Apr 19, 2005 | 10:12 PM
tec_wiz's Avatar
Default Re: (Dave421)
bump
mdrouillard1983
Mar 22, 2014 10:05 AM
italian_virus
Oct 17, 2010 10:43 PM
Subie2Honda
Jul 7, 2009 12:31 PM
Dave421
Apr 18, 2005 06:23 AM
