around how many hp to expect from this set up
Old Apr 17, 2005 | 03:40 AM
1heavy4dr's Avatar
Default t
Modified by OBD 1 at 5:09 PM 1/18/2007
Old Apr 17, 2005 | 08:46 AM
Racermech's Avatar
Default Re: around how many hp to expect from this set up (ALL VTEC)
Any guess at HP would be just that a guess. It is gonna be 100% up to the tuner, if they do a good job I am sure you will pull some good number, But a bad tuner will cost you a lot of HP.
Was the ECU programed before or after the build?? If it was before you will want to look into getting it done again, or going with hondata, or uberdata
Old Apr 17, 2005 | 07:21 PM
1heavy4dr's Avatar
Modified by OBD 1 at 5:10 PM 1/18/2007
Old Apr 18, 2005 | 01:20 AM
greasemonkee's Avatar
Default Re: (xecute 2)
Interestingly enough, that setup is nearly identical to mine with the exception of the valves (stock), valve springs (ITR), ignition (stock), ECU (stock), block (all stock), tranny (ITR), and header (type one). I'm seeing around 168, which aint too bad for a stock block and stock rev limit... I hope.
It want's to twist higher, but those heavy valves are saying NO. Nevertheless, that's still like comparing apples to kiwi.
DrivinVtec
Oct 4, 2007 04:02 PM
accord380whp
May 16, 2007 09:31 AM
CivicSI1018
Dec 6, 2004 06:21 AM
GapxGuy
Feb 12, 2003 10:13 PM
Mr. Softee
Jan 13, 2002 03:17 PM
