h22a swapped accord 6500 revlimit kicks in?
Old Apr 16, 2005 | 11:28 PM
R6E6I6D's Avatar
Default h22a swapped accord 6500 revlimit kicks in?
i got a 95 accord with a h22a and i have had zero problems with the car so far except the vehcile kicks revlimiter @ 6500rpm in every gear andi know the stock redline on my motor is much higher than this, I think when i was drving with the owner b4 i got the car that day he reved to 75 grand and it was smooth but eversince i got it home and drove it twice it has been acting up? if anyone has any idea why its doing this give me a little help, thanks
Old Apr 16, 2005 | 11:42 PM
cpforyou's Avatar
Default Re: h22a swapped accord 6500 revlimit kicks in? (R6E6I6D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R6E6I6D &raquo;</TD></TR><TR><TD CLASS="quote">i got a 95 accord with a h22a and i have had zero problems with the car so far except the vehcile kicks revlimiter @ 6500rpm in every gear andi know the stock redline on my motor is much higher than this, I think when i was drving with the owner b4 i got the car that day he reved to 75 grand and it was smooth but eversince i got it home and drove it twice it has been acting up? if anyone has any idea why its doing this give me a little help, thanks</TD></TR></TABLE>
Is the check engine light on?
If not, check your engine oil. See if it is at the right level.
Old Apr 17, 2005 | 11:50 AM
madjdmy0's Avatar
hey, that was my friend that posted for me, but i have the maintenance required light on(the green light at the bottom of the cluster). But oil is good and no check engine light. I have brought it up to 7000 before but maybe only 2 times, every other time it bounces off at 6500. What else could i check out?? Could it be the Vtec solenoid?
-Terry
Old Apr 17, 2005 | 02:04 PM
H22NOSACC's Avatar
Default Re: h22a swapped accord 6500 revlimit kicks in? (madjdmy0)
I'm assuming that you just bought the car, so with that in mind, check to make sure that you have the right ecu it should be a P13, the previous owner may have switched it on you.
Old Apr 17, 2005 | 02:42 PM
madjdmy0's Avatar
Hey, well i thought that but the stock redline is set at 6200 so i figured it wasnt the ecu. So, i disconnected the battery to try to let the ecu re learn everything then 15 minutes later i put the battery back on. Then the aftermarket alarm system started to go crazy so i had about a 1 hour battle trying to figure out the alarm system. I disconnected the brain and still i would go to crank it and nothing would happen. So i hooked everything back up and i used the handheld unlock, lock remote thingy and i hit the unlock a couple of times and held it down and just fiddled with it and the alarm shut off. Then i started it and let it idle for 15 minutes and took it for a spin and the vtec works really good and it pulls hard in 1st . so yeah, i think it was becuase my maintenance required light was on that caused this problem, so if this happens to anyone else you should just try to unplug the ecu and take the fuse out for at least 15 minutes and then let it idle for 15 minutes to let it re learn and drive it around.
-Terry
Old Apr 17, 2005 | 05:02 PM
93accordEX's Avatar
maintenence required has no effect on anything. the times that it didn't work was your car not warmed up?
Old Apr 18, 2005 | 05:44 AM
madjdmy0's Avatar
Default Re: h22a swapped accord 6500 revlimit kicks in? (93accordEX)
Yes my car was warmed up...
-Terry
ricekiller1
Mar 9, 2004 05:24 PM
D21X
Sep 15, 2003 09:05 AM
