~HELP~ engine swap wont start no fuel
Old Apr 16, 2005 | 09:37 PM
screen_name's Avatar
Default ~HELP~ engine swap wont start no fuel
i have spark but no fuel, the fuel isnt getting to the fuelrail any suggestions?
Old Apr 16, 2005 | 09:38 PM
Luserkid's Avatar
Default Re: ~HELP~ engine swap wont start no fuel (LB562)
Is your fuel pump priming?
Old Apr 16, 2005 | 10:10 PM
airplan727's Avatar
Did you plug the fuel pump back in. Or check on the fuse or whatever for the pump? Can you here the pump if you turn the key on? It can take a while to bleed the fuel lines. Take the bleeder bolt off the fuel filter and see if there is fuel there and if there is then loosen the line on the rail and see if you have any fuel there. Then check and see if there is any fuel going through the return.
Old Apr 16, 2005 | 10:12 PM
Default Re: (airplan727)
too late right now ill check tomorrow and keep you guys posted
Old Apr 17, 2005 | 09:10 AM
nope i took off the cover under the rear seats and i dont hear any clicking...
Old Apr 17, 2005 | 09:32 AM
took off the fuel line from fuel rail to fuel filter no fuel there..
Old Apr 17, 2005 | 09:33 AM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LB562 &raquo;</TD></TR><TR><TD CLASS="quote">nope i took off the cover under the rear seats and i dont hear any clicking...</TD></TR></TABLE>
Its not a click, its a hum that you listen for. Check this fuse, it might be blown:
In this pic its a 25 amp but yours should be 15.
Old Apr 17, 2005 | 09:40 AM
Default Re: ~HELP~ engine swap wont start no fuel (Luserkid)
yeah i checked that fuse its still good. i hear no humm or anything. i use that as a kill switch :-p
Old Apr 17, 2005 | 09:41 AM
hey luser what kind of work do you guys do?
Old Apr 17, 2005 | 09:44 AM
Luserkid's Avatar
PMed you.
airplan727's Avatar
Good have a bad fuel pump. Check to see you are getting power or if you have a ground qith a tester (looks like a screw driver with a cord and a liught). To test for power connect the clip to a ground and probe the positive wire on the pump. To test for ground connect the wire to the positive side of the battery (you'll need something to extend the wire) and probe the ground wire at the pump. If both of those are good then you need a pump if there are no elecrtical problems.
Old Apr 17, 2005 | 09:47 AM
you guys rock thx for the help, ill go try that right now
Old Apr 17, 2005 | 10:16 AM
Default Re: (LB562)
huy... i cant find a regular tester, any other way to check if its electrical or the pump itself?
Old Apr 17, 2005 | 12:52 PM
navin's Avatar
Default Re: (LB562)
check the main relay
Old Apr 17, 2005 | 05:35 PM
Default Re: (navin)
i got the main relay, how do i check if its good or not
Old Apr 17, 2005 | 09:19 PM
airplan727's Avatar
Not sure how can test it without the tester. If you go to an autoparts store they should have one of them for just like $20. You don't need a meter, just something that turn a light on if there is anything going to the pump. You might even be able to rig something up yourself with some aligator clips and a light bulb.
Christopherian1982
Dec 31, 2008 08:17 AM
JDMITRTURBO
Dec 12, 2007 05:06 AM
blinger
Sep 1, 2007 10:35 PM
NSfit
Nov 28, 2006 07:35 PM
eg6_lsi
Mar 25, 2004 10:29 PM
