VSS wires. need help
Old Apr 16, 2005 | 08:52 PM
Snail Tuning's Avatar
Default VSS wires. need help
ok we did a b18b swap in a civic, and these wires were pulled out of the vss. and sense the engine is from an interga i figured this would be the best and fasted place to find the answel.
so.....
there are 3 wires. one is black, one is black with yellow stripe, the other is orange.
Old Apr 16, 2005 | 10:11 PM
Default Re: VSS wires. need help (Snail Tuning)
i forgot the info on the engine. its a 1995 engine. was told it was JDM but obiusly its not cause of the battery location.
so it does have a USDM obd1 harness on it. any help would be great. need this done by tomarow.
Old Apr 17, 2005 | 06:20 AM
this can be deleted. i fiddled around till i got the wires in the right order.
Modified by Snail Tuning at 7:57 AM 4/19/2005
Old Aug 6, 2005 | 10:23 PM
CivicVX94's Avatar
i'm bringing this back from the dead. i have this prob can you tell me the order? thanks
Old Aug 7, 2005 | 08:19 AM
CivicVX94's Avatar
Default Re: VSS wires. need help (CivicVX94)
bump
Old Aug 7, 2005 | 09:37 AM
Yambor's Avatar
well its a 3 wire 5v sensor, therefore, with the connector facing up, as in the clip up, ABC, Power, Signal, Ground...Just FYI, the middle wire of a 3wire sensor is the signal wire.
Power is BLK/YEL , ground is BLK and 5v ORN wire.
With the ignition switch in ON (II) or START (III), battery voltage is supplied from fuse 24 through the BLK/YEL wire to the Vehicle Speed Sensor (VSS) . The sensor is grounded by the BLK wire. The speedometer and other control units in the circuit supply about 5 volts to the ORN wire. The vehicle speed sensor (VSS) intermittently grounds the ORN wire which generates a pulsed signal in it. The number of pulses per minute increases/decreases with the speed of the car.
Old Aug 7, 2005 | 03:51 PM
CivicVX94's Avatar
Default Re: VSS wires. need help (JH4DC4-2GSR)
thanks for the help man, that part of my engine is working good now
KDvtec5757
Jul 13, 2009 04:49 PM
c rex 88
Dec 28, 2005 05:50 PM
RTW DC2R
Dec 13, 2004 07:34 PM
