88-91 crx or civic motor swap, swap from an 90 integra
Old Apr 16, 2005 | 06:14 PM
asocallocal's Avatar
Default 88-91 crx or civic motor swap, swap from an 90 integra
can i just use part for part?
let just say i have a 89 crx and a 90 integra. can just take everything from the 90 integra to complete the swap for the crx so it would be a b18a crx?
need to know if: mounts, linkage, ect... will just bolt on. i want to do a motor swap and just want to know what else ill need. thanks in advance
Old Apr 16, 2005 | 06:42 PM
Ronin150's Avatar
Default Re: 88-91 crx or civic motor swap, swap from an 90 integra (asocallocal)
If you use the integra shift linkage it will need to be shortend. I'm not sure if the mounts can be used from the integra.
Old Apr 16, 2005 | 06:50 PM
EP3_05's Avatar
As was mentioned the shift linkage will need to be shortened. You can use the axles from the integra. The motor mounts wll work if you cut, relocate, and then reweld the existing motor mount brackets in the crx. IMO I would just get a mount kit and not worry about having to relocate the brackets. There are other things like wiring and hubs that will depend on the model civic/crx used.
Old Apr 22, 2005 | 06:40 PM
up
G-Auto*Hero
Aug 4, 2011 03:15 PM
b20vtech
Nov 7, 2008 04:37 PM
4thgenlude
Aug 28, 2005 03:29 PM
Ding
Oct 25, 2004 04:15 PM
giff74
May 27, 2004 01:24 AM
