CR-V oil pump in B18C1
Old Apr 16, 2005 | 05:42 PM
mugenhatchie's Avatar
Default CR-V oil pump in B18C1
Hey guy's my B18C1 has a CRV oil pump that replaced the stock one that went out. I have been geting an oil pressure light any time my motor drops from cruising to idle speed. i tested out the oil pressure today and it was only at 8 psi at idle and 40 psi at 3000rpm. i think this is because the pump is from a non vtec motor so it doesnt put out enought psi for a vtec motor. am i right?? Also pistons rings, rods and bearings are all brand new. Any help would be great. Thanks.
Old Apr 16, 2005 | 07:00 PM
locash's Avatar
Default Re: CR-V oil pump in B18C1 (4door14's)
The pumps are identical.
98 CRV Oil Pump - 15100-P72-A01
98 GSR Oil Pump - 15100-P72-A01
Old Apr 18, 2005 | 07:25 AM
so why is my oil pressure so low??
Old Apr 18, 2005 | 07:48 AM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4door14’s &raquo;</TD></TR><TR><TD CLASS="quote">so why is my oil pressure so low??
You either have excessive clearance somewhere where you shouldn't have or a failing oil pump. Plain and simple.
b20eghatch
11
Jul 12, 2010 11:24 AM
94ludeJDM
May 4, 2007 06:13 PM
b18civicguy
Jan 12, 2006 09:25 PM
shannon
Dec 9, 2003 05:09 PM
untuned
Nov 1, 2002 07:43 AM
