skunk2 intake manifold/stock gsr
Old Apr 16, 2005 | 05:27 PM
DANG YO's Avatar
Default skunk2 intake manifold/stock gsr
i have a 97 gsr and i am wanting to put a skunk2 intake manifold on my car.. i was wondering if it will still run good with my stock ECU since it has fuel maps for the secondary butterflie that i will no longer have.. please lemme know!
also anything extra i need to install this manifold on my car except gaskets??
will alll my stock stuff including my ecu work perfect?
please lemme know asap! thanks in advance
Old Apr 16, 2005 | 05:38 PM
mr.beeks's Avatar
Default Re: skunk2 intake manifold/stock gsr (dc2kid)
stock ecu will run on limp mode since it still thinks it has
the secondaries and will try to look for it
also the car will bog out......
Old Apr 16, 2005 | 06:16 PM
IggyBcool's Avatar
Default Re: skunk2 intake manifold/stock gsr (mr.beeks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.beeks &raquo;</TD></TR><TR><TD CLASS="quote">stock ecu will run on limp mode since it still thinks it has
also the car will bog out......</TD></TR></TABLE>
yuup, hit up Ih8ricerz for a chipped p28. also a single stage im isn't going to really make any difference unless u have some mods done to it
Old Apr 16, 2005 | 08:22 PM
Pnoyej6's Avatar
* B A N N E D *
Default Re: skunk2 intake manifold/stock gsr (99LStegra)
im gonna sell my skunk 2 im sinc eim gonna get the jrsc kit on my stock gsr. Im running on stock ecu and had no problems
Old Apr 16, 2005 | 08:40 PM
Nextelbuddy's Avatar
what are you talking about???? the ECU does not throw ANY CEL's when the secondaris are not hooked up...
i ran a stock P72 obd1 ECU for a little while after installing my edlebrock intake manifold and never had a problem...
teh ECU sends a RPM activated signal for the secondaires but has NO return signal what so ever... the motor will NOT bog down and will run just fine.. although the P72 ECU wont be the most optimal ecu for a skunk2 or edlebrock manifold it wil not cause any major noticable problem
Old Apr 16, 2005 | 08:41 PM
DANG YO's Avatar
Default Re: skunk2 intake manifold/stock gsr (pnoytegn707)
what year is your car? can u feel it lag until the usual secondary butterflies would have opened? does it run good and did u notice a power increase?
Old Apr 16, 2005 | 08:43 PM
Pnoyej6's Avatar
* B A N N E D *
i have 00 gsr and no lag . good top end power. Here is a pic bro.
Old Apr 16, 2005 | 08:44 PM
i dont have that setup anymore... but i also ran a P72 ecu on a ITR motor with no issues.. vtec engages as normal. the ecu sends a signal for the secondaries but since theres nothign there to recieve the signal obvisouly nothign happens.. the ecu gets no return signal saying OOPS THERES NO SECONDARIES THERE so no problem there....
i had a 95 gsr motor as well as a 2001 gsr motor with no issues this way...
Old Apr 16, 2005 | 09:12 PM
DANG YO's Avatar
did u have to change anything else or buy any extra parts when installing the manifold other then gaskets? also did it re-tain all factory sensors and NO CELs?
Old Apr 16, 2005 | 09:20 PM
Pnoyej6's Avatar
* B A N N E D *
i have to buy couplers. Intake manifold gasket,tb gasket. I bought a itr tb and itr cable and bracket because my stock gsr tb was hitting my hood and getting stucck.
Old Apr 16, 2005 | 09:24 PM
DANG YO's Avatar
what couplers did u have to buy?
Old Apr 16, 2005 | 09:30 PM
Pnoyej6's Avatar
* B A N N E D *
You need longer hoses and couple them together
Old Apr 16, 2005 | 09:33 PM
DANG YO's Avatar
longer hoses for what?
Old Apr 16, 2005 | 09:39 PM
Pnoyej6's Avatar
* B A N N E D *
Check the article
Old Apr 16, 2005 | 11:10 PM
kchungb17a's Avatar
VTEC engagement is way too low on a P72 ecu for a single stage manifold (4500rpm @ wide open throttle). You will notice a bog in power at that point. A P61 (92-93GSR) or USDM del Sol VTEC ECU would have a better VTEC point (5700rpm @ WOT). As stated above, to maximize the potential of that manifold, you should get upgraded valve train for high(er) rpm operation and cams that give you power beyond 8krpm.
As for the check engine light, I know for certain that an OBD1 ECU does not throw a code for that, but it is possible that an OBD2 ECU might, seeing as how OBD2 is all about making our tuning lives difficult.
Old Apr 17, 2005 | 07:40 AM
DANG YO's Avatar
Default Re: skunk2 intake manifold/stock gsr (kchungb17a)
would it be safe to run my car on a P30 ecu (obd1 b16 ecu)
Old Apr 17, 2005 | 10:43 AM
kchungb17a's Avatar
Yeah... that's the one from the del Sol, right?
Old Apr 17, 2005 | 10:46 AM
.water's Avatar
i heard u get good gian with ported/polished Stock GSR manifold. also removed 2nd butterfly. Erick's race car was using this. &lt;--heard it.
Old Apr 17, 2005 | 12:34 PM
Rollo Lawson's Avatar
you might want to look into the AEBS gsr im. it was actually designed for the gsr head. and, if you don't have any REAL mods, and have no need to rev above 8200rpm, then a port matched oem gsr im w/hondata im gasket should net you good gains without any midrange loss, which is what will happen if you intall the S2 im.
BOMBAY
13
Jun 2, 2007 03:52 PM
nuklang
Oct 4, 2006 09:57 AM
escape2me
Apr 26, 2006 04:47 PM
B19CivicHB
Jan 22, 2002 02:13 PM
