QUICK QUESTION: with my setup how far can i mill the had to reach a desired compression ratio?
Old Jan 30, 2002 | 08:07 AM
gokooljapan's Avatar
Default QUICK QUESTION: with my setup how far can i mill the had to reach a desired compression ratio?
im planning on putting my B17A head on a type r block. if i mill (deck) the head 30 thousandths, would this be safe? as in piston to valve clearance? and also, where do you think my compression ratio would be?
by the way, im using a stock head gasket and CTR intake cam, dual valve springs(OEM type r)......block will NOT be decked or milled.....
any help would be kindly appreciated.....
Old Jan 30, 2002 | 08:10 AM
Spade's Avatar
Default Re: QUICK QUESTION: with my setup how far can i mill the had to reach a desired compression ratio? (
http://www.c-speedracing.com
look into there clay topic under how-to.
Clay your engine and then figure out from there.
Old Jan 30, 2002 | 08:47 AM
RedlinedVTEC's Avatar
You shouldn't be milling or decking to gain a higher cr. You should invest in a mugen head gasket or similar setup that will lower the cr. Also look into higer cr pistons. Milling the head is only viable if there is damage to the head ie a scratch that would prevent the head gasket from properly sealing. It also throws off the timing and is basically looked down upon for gaining cr.
Old Jan 30, 2002 | 08:51 AM
JG Luder's Avatar
Mostly what he said.
Milling can be used in moderation. But pistons are the way to go if you want any performance gains. Milling it is just a means to an end... and the trouble you will possibly have are unforseeable until you've actually done it.
The clay test is a good indication for valve clearance, however, it still won't tell you what timing problems you're going to have, and how much you're going to be off.
Old Jan 30, 2002 | 10:07 AM
ok, thanks for the replies.......
another question then, what is the SAFEST or the most you can RESURFACE your head.....meaning when is the head useless? i know there are indicator marks on the head which tells you something, ?........so basically is 30 thousandths still ok to use the head?
the indicators are show that there is still enough play, so im assuming that i am safe, hopefully that is =\
Old Jan 30, 2002 | 10:08 AM
JG Luder's Avatar
I'd talk with a local, reputable machine shop in your area to see what they think they can do.
Outside of that, I'm going to have to let the number techies tell you what will and won't work.
Old Jan 30, 2002 | 10:43 AM
rainforest's Avatar
every .010 taken off is .2 compression. just some info to help.
Old Jan 30, 2002 | 09:18 PM
peebrain's Avatar
so if the tabs are untouched....can u be safe from tapping..
gsr head milled .40
b16a block(p30)
ctr cams...can i tune still...and be ok on clearence since its using all vtec parts and not like say a stock ls block..
Old Jan 30, 2002 | 09:28 PM
teg92's Avatar
No the tabs are only there to ensure the head is still with tolerable usibility, i.e. still strong enough and has enough metal between certain areas to hold itself together.
vajdmeg
Jan 30, 2009 11:01 AM
kc4door
Jan 22, 2006 05:47 PM
fredtoast
Feb 16, 2004 10:25 AM
Kellindal
May 18, 2003 10:12 PM
