Need advice, they say my car has piston slap?!!
Old Jan 30, 2002 | 08:04 AM
dawson's Avatar
Default Need advice, they say my car has piston slap?!!
my 97 honda civic HX with 99K recently developed a knock upon start up on cold mornings. They said its piston knock and its nothing to worry about.... are they feeding me a line or what?
Old Jan 30, 2002 | 08:11 AM
Spade's Avatar
Default Re: Need advice, they say my car has piston slap?!! (dawson)
Good choice on model.
Yup, it's piston slap, common among cold honda engines.
Old Jan 30, 2002 | 08:53 AM
dirtySOHC's's Avatar
Default Re: Need advice, they say my car has piston slap?!! (Spade)
so it is common.....ppl tell me i might have a vacuum leak....the knock goes away when the motor is warm though
Old Jan 30, 2002 | 09:15 AM
sgT's Avatar
sgT
No honda engine I have ever seen with stock pistons has had any piston
slap.
Old Jan 30, 2002 | 09:20 AM
rainforest's Avatar
Default Re: Need advice, they say my car has piston slap?!! (sgT)
in a gangsta voice (true)
Old Jan 30, 2002 | 09:21 AM
Spade's Avatar
Hrm, my EX engine does it and it also has 99k on the od.
Old Jan 30, 2002 | 09:23 AM
sgT's Avatar
sgT
sounds like its getting worn out.
Old Jan 30, 2002 | 12:12 PM
Perfectionist's Avatar
slap.
FWIW, I'm the original owner of a '90 Civic Si. When I first picked it up, I took it back to the dealer because I detected a faint rattling noise. I was told it was piston slap. The aluminum pistons fit slightly loose in the bore until they heat up. Over the years, when the weather was like zero degrees, the cold engine sounded like a diesel until it warmed up. Anyway, long story short, the original engine has over 241,000 miles on it now and it uses about 6 ounces of oil between 4,000 mile change intervals.
Old Jan 30, 2002 | 12:35 PM
Spade's Avatar
Yeah I am gonna rebuild it some day...........Maybe.
Old Jan 30, 2002 | 02:47 PM
fiebru1119's Avatar
its normal, my g/f has a bone stock '96civic that does it in the mornings
[Modified by fiebru1119, 11:48 PM 1/30/2002]
Old Jan 30, 2002 | 02:51 PM
sgT's Avatar
sgT
Default Re: Need advice, they say my car has piston slap?!! (Perfectionist)
Not true.
Honda pistons run such tight clearances that it scares most (domestic)machinists.
Old Jan 30, 2002 | 03:08 PM
iceburgslim's Avatar
It's realy nothing to worry about, Honda issued a TSB stating that it's normal...not common but again nothing to worry about. Just give your car time to warm up.
Old Jan 30, 2002 | 03:11 PM
JG Luder's Avatar
Default Re: Need advice, they say my car has piston slap?!! (iceburgslim)
I've only heard of "piston slap" with forged pistons. That doesn't mean it doesn't happen with stock ones, just letting you know what I've heard.
Old Jan 30, 2002 | 07:38 PM
jetdriven's Avatar
Default Re: Need advice, they say my car has piston slap?!! (JG Luder)
piston slap is common with forged pistons because they have roughly twice the thermal expansion rate as cast slugs. So you have to run a looser piston-to-wall clearance with forged to make them work. Forged pistons are not common on emissions motors because of this, the cold emissions are terrible.
my 91 teg GS has piston slap too, i just let it warm up for 1 min before driving and dont worry too much.
Old Jan 30, 2002 | 11:16 PM
HaUTSaauce's Avatar
New User
warm up the car man
Old Jun 8, 2011 | 12:07 PM
gizmoto2000's Avatar
I have the same issue too and I do have forged pistons, so yea it must be something with em forged pistons - just let it warm up I guess...
Old Jun 8, 2011 | 12:08 PM
Ah f**k its 02 thread - honestly did not see that guys lol
Old Jun 8, 2011 | 05:38 PM
young-gun92eg's Avatar
i knew sombody that drove for quite a whille with a piston slap
Souls
Apr 23, 2026 10:11 PM
Alex809
Jul 17, 2014 10:33 AM
Hybrid96EK
Apr 29, 2010 09:10 AM
pootie.teng
Mar 12, 2008 02:00 PM
Firewalker
13
Apr 12, 2004 04:50 PM
