what pistons for more power..for h23
Old Apr 16, 2005 | 08:09 AM
92silude's Avatar
Default what pistons for more power..for h23
alright I have an h23, and I've been told about the type S pistons...but I don't know which ones to use in my engine...could someone help me out?
Old Apr 16, 2005 | 08:17 AM
LudeyKrus's Avatar
Get a set of OEM USDM or JDM H22 pistons. They will bump you up a good deal on compression; the Type-S H22's will be too high of a compression w/ your H23 head.
Old Apr 16, 2005 | 08:23 AM
92silude's Avatar
so just get some h22 pistons?
would I have to do anything with the block? or get anything else...or will they match right up?
Old Apr 16, 2005 | 08:45 AM
LudeyKrus's Avatar
Make sure you get the right piston: either A or B, you gotta check your block to see. And while that should be enough, I would personally either do it myself or have a machine shop check the cylinder-to-piston clearances to make sure they're in spec.
Doing this, you will need a new head gasket and rings, and might as well do normal maintenance stuff while you're in there (timing belt, water pump, etc)
roycivic92
Jan 28, 2006 09:21 PM
j_max420
Jul 9, 2005 09:42 AM
Jdmprelude94
Apr 16, 2005 09:10 AM
BoostedH23Accord
Sep 23, 2004 03:51 AM
canuck-mx6
Jan 24, 2002 06:33 PM
