type r: rear lower sub frame
Old Apr 16, 2005 | 04:15 AM
marko_think's Avatar
Default type r: rear lower sub frame
do all type r's have weld marks like this? top left..right above the sway bar
because this is mines
Old Apr 16, 2005 | 05:38 AM
fqnjdmboy's Avatar
Ummm those arent welds....they are seam sealer...
Old Apr 16, 2005 | 06:30 AM
Comp97GSR's Avatar
Default Re: type r: rear lower sub frame (marko_think)
Did you replace your rear sub frame with an ITR one? If I ever have a swaybar tear out that is what I would do. Looks clean!
Old Apr 16, 2005 | 08:24 AM
Alexander's Avatar
Default Re: type r: rear lower sub frame (Comp97GSR)
I wonder where you could source a Type-R subframe, short of finding an R shell?
Old Apr 16, 2005 | 08:32 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Comp97GSR &raquo;</TD></TR><TR><TD CLASS="quote">Did you replace your rear sub frame with an ITR one? If I ever have a swaybar tear out that is what I would do. Looks clean! </TD></TR></TABLE>
my sub frame came like that. is having seam sealer important?
Old Apr 16, 2005 | 09:45 AM
Big Teggie's Avatar
Default Re: type r: rear lower sub frame (Alexander)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alexander &raquo;</TD></TR><TR><TD CLASS="quote">I wonder where you could source a Type-R subframe, short of finding an R shell?</TD></TR></TABLE>
You can purchase a replacement subframe from the dealer.
Old Apr 16, 2005 | 06:18 PM
1993sir05's Avatar
everything on the car has a part number everything you can buy them from the dealer.
Old Apr 16, 2005 | 10:41 PM
db8sirg's Avatar
036 65750-ST7-R10ZZ CR/MBR, RR. FLOOR $165.49
Old Apr 17, 2005 | 08:25 AM
Alexander's Avatar
Default Re: type r: rear lower sub frame (db8sirg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by db8sirg &raquo;</TD></TR><TR><TD CLASS="quote"> 036 65750-ST7-R10ZZ CR/MBR, RR. FLOOR $165.49 </TD></TR></TABLE>
Damn, thanks!
Old Apr 17, 2005 | 09:15 AM
so when you buy that, you have to weld it on?
Old Apr 17, 2005 | 09:31 AM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marko_think &raquo;</TD></TR><TR><TD CLASS="quote">so when you buy that, you have to weld it on?</TD></TR></TABLE>
yes
Neptronix
Aug 14, 2008 01:32 PM
ALF
Dec 23, 2006 05:39 PM
Sinbro2
Jan 4, 2005 10:49 AM
SlammedBlueEM2
May 28, 2003 11:21 AM
CBR600OnTop
Jan 22, 2003 06:28 AM
