Assembly Lube: how soon to change oil
Old Apr 16, 2005 | 04:02 AM
PupaScoopa's Avatar
Default Assembly Lube: how soon to change oil
After using assembly lube, how soon should one change the oil? The total volume of assembly lube used is about 1fl oz, so I would feel ok running it mixed in 4qt of Mobil1 for at least a few hundred miles. Right?
Old Apr 19, 2005 | 10:05 AM
PupaScoopa's Avatar
Default Re: Assembly Lube: how soon to change oil (PupaScoopa)
up
Old Apr 19, 2005 | 10:09 AM
LSVTEC 91 Civic's Avatar
Banned
I put 100 miles on my first oil change. Don't break in with M1, use a dino oil.
Old Apr 19, 2005 | 11:15 AM
IN VTEC's Avatar
At least change the filter after the first initial start/warm-up when you set the ignition timing, bleed the cooling system, etc.
I change the oil and filter, but you should at the very least change the filter.
Old Apr 19, 2005 | 06:32 PM
Bror Jace's Avatar
Default Re: Assembly Lube: how soon to change oil (IN VTEC)
Which assembly lube did you use?
I know with new engines, Honda uses a special factory fill which is LOADED with molybdenum ... nearly 1,000 PPM in the samples I've seen analyzed.
I'm not sure what's in most assemply lube ... probably a lot of AW/EP additives but I still think at least the filter should be changed by the 1,000 mile mark.
Old Apr 19, 2005 | 07:29 PM
IN VTEC's Avatar
Default Re: Assembly Lube: how soon to change oil (Bror Jace)
It's a mixture of the green stuff from Clevite and ARP moly assy lube.
kidcool1977
Oct 27, 2008 05:40 AM
AutoXer
13
Sep 8, 2005 12:11 PM
Jarmer
Jun 14, 2005 10:23 AM
1998_4dr_gsr
May 19, 2005 05:53 AM
mr poo
Aug 4, 2003 04:38 PM
