How exactly do you check the relay for fuel
Old Apr 15, 2005 | 10:40 PM
yellowmonkeyboy's Avatar
Default How exactly do you check the relay for fuel
del sol 95, how exactly do you check the relay for fuel to see if it is working, and which relay is it? thanks
Old Apr 15, 2005 | 10:41 PM
handa's Avatar
Default Re: How exactly do you check the relay for fuel (yellowmonkeyboy)
i'd like to know also. bump!
Old Apr 15, 2005 | 10:48 PM
doh i htought you answered the question, oh well bump
Old Apr 15, 2005 | 11:03 PM
Ninety5Ex's Avatar
Listen for the pump priming when you turn the key to on. The relay is black and up there above the fuse box.
Old Apr 15, 2005 | 11:28 PM
GdmLaz's Avatar
when you turn the key be4 you actualy turn it to crank position you should hear the fuel pump turnin on if you hear it the relay is working
3easy21
Jun 11, 2012 07:27 PM
jerome^galon
Jan 4, 2012 07:03 PM
srt4pilot
17
Jun 10, 2009 12:57 PM
CoolRedXylophone
Jan 22, 2006 06:45 PM
